I just gave my car a little right foot on the freeway in 4th gear and noticed i was hitting 10psi at 4000rpm instead of after 5000rpm.
So I'm guessing my lag issue is all in the tune. Can it really make that big of a difference
Lag will be less in higher gears. This is because there is more load on the engine in higher gears. It wont be the same in every gear.
What gear does it take till 5000rpm to hit boost?
In 1st and 2nd i'm not getting 10psi till after 5000rpm just noticed this morning in 4th and 5th im getting 10psi around 4000rpm.
So theres slightly over 1000rpm difference, don't forget Stao said this turbo should be getting 20psi by 4300 so i would epect 10psi by say 3200 - 3500
With the stock comp housing, you ended up with half mm each side of the intake pipe. lol. But do run it with 3inch intake pipe, stock pipe will restrict power flow.
Because the stock turbo intake is being used it will need to start at 2.5" or 60mm (turbo end) and then increase to 3" as quickly as possible. Something like this is as good as I can find:
http://cgi.ebay.com.au/ALLOY-INTAKE-PIPE-4...=item25597be9f9
Is there any advantage to increasing the pipe size to 3" if its restriced to 2.5" at the turbo intake anyway?
Edited by Harey
Im not commenting on the overall responsiveness of the turbo, but I could imagine somewhere near 1000rpm difference in lag between 1st and 4th gears.
ok so then its still has extreme lag.
Any one got a dyno sheet of the ATR43G3 showing boost and rpm?
This has power and speed.
http://www.digi-hardware.com/images/dynosh...rwkwcompare.JPG
Post up yours and we can compare.
No Dyno yet in the process of raod tuning the car, maybe i haven't been aggressive enough on the timing
Also going to replace my oil drain as i suspect maybe there is a kink in it
Edited by Crans
if you dont understand that boost repsonse is different in 1st and 2nd to 4th and you don't know how fast turbos spool up exponentially, tuning your car yourself is going to end up in tears
Yes i understand boost response is different between the gears and exponential growth in spool. I just didn't realise there would be over 1000rpm difference between 2nd and 4th not to mention extreme lag is still a problem
I am only doing basic mapping on the street i.e. getting fueling as close to perfect as i can and getting some extra timing in to help response, the rest will be done on a dyno.
I have tuned other cars before with ok results and being very safe and reliable still.
Based on this dyno print out of boost vs RPM http://www.digi-hardware.com/images/dynosh...3boost15psi.jpg i should be making 6psi by 3000rpm and 10psi by around 3300rpm
Edited by Crans
most turbo cars with decent sized turbos will have 1500-2000rpm spool difference between 1st and 4th gear
OK cool i didn't realise the difference was that much.
Oh wow its not tuned yet!! I agree with other people here, spend the cash on a professional tune. A tune will greatly affect the response of a turbo. It will be worth its weight in gold.
I think its unfair to give Hypergear bad feedback without a proper tune.
Edited by Harey
Not giving bad feed back at all, when boost does come on it feels very strong. I am going to tune the car my self and get it checked and adjusted on a dyno.
Like a lot of people i would prefer to do most of the work my self and learn on the way.
Other thing needs to be mentioned is that ATR28G4 unit is running a .82 turbine housing. The one with full boost at 3500RPM is running on .63 turbine housing.
.82 turbine bousing based boost and power curve should be:
http://www.digi-hardware.com/images/dynosh.../atr43360hp.jpg
All the new ones now has the wastegate controller lever, which allows you to run 20psi+ in a steady curve.
Also get rid of your stock rubber pipe. You can't get a decent tune out of that, it will suck bend and suck it self partially shut in random shapes. impossible to get get a constant air flow and reading. I've chucked mine out and replaced it with a 3inch metal pipe. Heaps of difference in power and response.
You mean a metal pipe that is 2.5" at the factory turbo end and increases to 3"? Or are you not talking about a PU hiflow?
Something like this:
Edited by Harey
No mine has a 3" inlet
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
