You are going to need a 2.5 inch to 3 inch reducer pipe in 45 degrees, connect that into a 3inch straight metal pipe, then a 3inch straight hose to AFM with a good pod filter fitted.
Stock BOV is a big problem. Once stock BOV is disconnected from factory intake pipe it will "not leak" but instead sucking un-measured air in before hitting with positive boost pressure. So you can either fit a One way valve in between the vacuum source or get a aftermarket BOV.
To do either of that you must re-locate your AFM into cooler piping, Block off the factory BOV port and fit your BOV before the AFM. else it will affect idle on deceleration (or you can decelerate in gear which will has no affect on idle).
Wow that sounds like a major pain in the arse. Surely there is a simpler way.
Is the factory rubber pipe the right size?
I have read someone with 300rwkw did this:
- Intake pipe strengthened with internal steel pipe to stop sucking close
Is this an option?
As long as the intake pipe is no more restrictive than the MAF sensor you should not loose power.
that's the rev210 mod... search it... massive thread
i did the same... shoved a 3" stainless steel pipe in there... works a treat. no issues whatsoever.
Cant you just make a 3inch intake pipe then use a 2.5inch to 3inch silicon off the turbo to amke it fit and whats the probelm with the bov that has to make it change the afm and what not?
stao, im still not 100% happy with your response, i paid $150 extra for a high pressure actuator (15-18 psi you clamied) ... so can you give me a better response then " I need a metal intake pipe" to resolve the fact the actuator is only holding 12psi?
i have the rev210 mod and trent (status) said it wasnt sucking shut... the metal intake pipe will not help me pick up and hold 4 psi
From what boost is it dropping to 12 from? on mine it drops from about 17.5 to 14.8 on redline its more due to because of it being a 0.63.
The turbo is running in .63 rear housing. the actuator on it has a 1.3KG spring loaded. You will definitely get a boost drop due to intake pipe restriction. It doesn't necessarily shut in full. But more partially shut in different areas.
You will get a higher boost reading with a 3inch metal intake pipe and a slight adjustment with actautor pre-load, or actautor pre-load along.
The later versions runs a waste gate control valve like what i've made for Ric's car. I've made one and tried to ring you today for pickup had no answer. Once that is installed you can hold what ever boost you want. Please ring me and organize a date and time to pick up this part.
yeah ric, stao is right.. its a 0.63, not 0.82 ;)
its peaking at 17.5 and dropping and holding 12 psi... i have performed the rev210 metal intake mod to prevent the intake closing...
also the maximum amount of preload has been set.... no more thread left on the adjustable rod
do you have a higher sprung actuator then the one you proveded me?
Well I've noticed mine stock intake pipe twists under high boost with a bigger turbo (ATR43G4). It twisted and stood up like a rattle snake with AFM and filter removed. I have my afm in between cooler piping. Then shut and car breaks down.
ended up tuning with no intake pipe or filter. worked heaps better.
I haven't tried this new wastage valve thingy, but with my OP6 rear, the .63's won't hold flat boost. I've got a mammoth actuator on the car at the moment (boost controller off it runs 18psi :D) but will always drop that 3-4psi etc. That's the housing, not the actuator.
And i'm pretty sure you'll find that with any turbo of similar size, you're not going to hold that sort of psi to redline. GCG highflow, HKS GTRS, HKS 2835 ProS... you'll find very similar boost curves.
We overlaid a HKS 2835ProS boost curve with my OP6 rear housing curve, and they were very similar... the HKS just held out every so slightly longer, but it was very similar (and also a $4k kit i believe)
So it's not an issue with they hypergear highflows... it's just a trade off for having a housing that is more street friendly.
To be honest, i'm glad it doesn't run 17 or whatever at redline, even running E85, i'm not fussed it tapers off a bit. Sure it doesn't look pretty on a graph... but i'm sure your engine is preferring it :D
Stao the intake pipe is not the issue on this car. The actuator is fully preloaded.... it has no thread left to wind in more. Have you got a 18psi base pressure actuator available still? I know we are going to get drop but it could be improved a little with more preload.
I havent used the new mod you are doing to the turbos (like ricks actuator flap restricor) but im concerned about big spikes on gear changes, have you had much feed back? i really don't want to play guinea cop with a customer. (NOT CRITICISM JUST A QUESTION)
I would like to know this too! 18psi wastegate actuator would be much preferred!
i don't want to be said guinea p1g either :down:
someone else try it and let me know how it goes :)
Surely an 18psi wastegate actuator is the proper way to hold boost to redline as well (assuming it must be internally gated). The other way sounds like a band aid to me.
Edited by Harey
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
