lol problem was .63 dropping. not .82. PU comes in both .63 and .82 depends on what people wants. Also I had a customer making 21psi to red line in .63 internally gated. I'll be seeing this guy's car on the weekend and should be able to sort it out.
We have an example here. SSGOhan here's running a high flow with a OP6 housing with a 20psi actuator. See what’s happening here? his getting 18psi with no boost controller and experience a boost drop to 16psi at red line.
thats fine, and its SSGOhans car and results that we are trying to replicate with mark and nicks car, 18 dropping to 16 (i have all daniels graphs) is fine but we are getting 18 dropping to 12 with the actuator that was supplied hence i asked mark to upgrade.
I understand it is never going to hold till redline with the 0.63 but the increase of boost from 12 to 16 with the bigger actuator could give us as 20-35rwkw.... a great outcome.
Hi Trent. you mean Ricks car? he's definently have the high pressure actautor, I tested it on front of him before putting it on. He's also got the wastegate controller installed, Have you had a play with it on the dyno? That will hold 18psi red line.
Also he's turbo is in a totally different profile to either Daniel or Mark. It will be the most responsive out of all 3, How ever marks should have the highest torque.
I will check mark's actuator and few other things this weekend.
Plus do you still remember that light blue R33 you workedon towards the end of last year? that guy's got exact high flow profile in .63 turbine a Marks with the same actuator. He's holding 21psi to red line. Did he came back after running into few trees? (he said he had an accident when I rang for some feedbacks.)
Its just strange same actautor on the same turbo gives all sort of results on the same type of engines.
Few photos added in modifying intercooler pipe to suit a BOV. Photo shown the driver side pipe that is connected to the outlet of the cooler.
Its a HPVA BOV. We make them as well.
As some of you've might seen. This is ATR43G4 in .82 turbine housing Running internally gate with high pressure actautor.
In generally you will find .82 turbine housing and high pressure actuators work pretty well on RB25dets. made 321rwkws@22psi.
so i have an r34 rb25det neo, and i want to upgrade the turbo.
I have all supporting mods to get to 270rwkw, but I'd rather have like 250 with better response. So can you recomend a turbo ATR43G2? or could i get that result with my stock turbo highflowed?
We can do a SS2 high flow to your stock turbo. which will make 260rwkws with stock standard response. Every thing bolts back on with no modifications required.
funny that the 3071 keeps pulling past 7k yet the others dont...
Please see this thread for which cars were selected etc:
http://www.skylinesaustralia.com/forums/Qu...urbo+comparison
Its far from a perfect graph. It took me a lot of time, feel free to make your own thats better. These are all real dyno graphs.
I just used it as a way to show the pre 3000rpm performance of the stock turbo.
I've high flowed few in 2860RS spec. and it was more responsive then stock.
SS2 is a T3x .63 rear running a 2871RS spec CHRA in 52T comp using Stock housing. will get full boost by 3000rpm and max about 260rwkws.
Also Waste gate lever controller for stock R33 turbo high flowed units. Controller is optional, and cost more to make.
(note: Wheel profile made to use with this type of turbine housing is different to standard high flowed units. Slightly more lag, lot more top end.)
how does mine compare to this Stao?
I see you have changed the position of the wastegate controller, much better :D
hello stao
ime interested in your atr43g3 with .82 rear for an rb25det r33, and also your atr43g2 with .82 rear what is the diff between the two. me chasing 280 300rwkw.
ive been looking at garretts gt3076r and cant decide between them or you. what would u have close to that
and also would a .63 rear be cappable of my power goal. and what sort of lag would i be looking at between the .63 and .82 rears, thanks.
We can supply all Garrett BB CHRA in what ever combinations you want.
The GT3076 56T running .82 housing with waste gate controller will get you about 300rwkws at 23psi. We can build this model based on a .82 T3 OEM bolton turbine housing with .60 Garrett anti surge comp housing and a big can actuator for $2200 including GST. All your stock lines fits. You see full boost about 4200RPMs with this model.
The sleeve bearing of above is ATR43G3. its about 200RPMs laggier, archives identical amount of power and power curve.
With .63 turbine housing we recommend a custom 3576 or 3582 profiled running .70 A/R comp. It can get you around 290rwkws with better response through gears.
what would the atr43g3 be like at 18 psi
and this is $1450 against $2200 and ile only lose 200rmp of lag.
is the afm the same diameter as the inlet. and u said i could achive my goal with one of these was that with .63 or .82 rear
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
