geraus Posted June 8, 2010 Share Posted June 8, 2010 nup not yet, next week Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5282337 Share on other sites More sharing options...
boostn0199 Posted June 8, 2010 Share Posted June 8, 2010 Should be interesting so this is the pu hi flow that stao almost hit 300 with? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5282448 Share on other sites More sharing options...
hypergear Posted June 9, 2010 Author Share Posted June 9, 2010 I've modified that rear housing alittle since tuner mentioned it was too hot. Should have more chance of hitting 300rwkws now with a larger turbine housing. Just depending on how hard he wants to push the car. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5282699 Share on other sites More sharing options...
boostn0199 Posted June 9, 2010 Share Posted June 9, 2010 What do you predict it to hit full boost at and also rough power at 18psi? and how much is the turbo with a stock one provided? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5282797 Share on other sites More sharing options...
hypergear Posted June 9, 2010 Author Share Posted June 9, 2010 With this specific profile. full boost around 4500RPMs. at 18psi and a good tune should see some where around 270~290rwkws. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5282850 Share on other sites More sharing options...
SimonR32 Posted June 14, 2010 Share Posted June 14, 2010 (edited) just got a call... car went 340hubber hp (253kw) on 1.5bar (no dyno correction) standard rb20det gtr injectors z32 afm atr43g3 0.63 on standard manifold will get a graph up tomorrow Edited June 14, 2010 by Cerbera Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5292021 Share on other sites More sharing options...
kwickr33 Posted June 14, 2010 Share Posted June 14, 2010 Thats pretty good result for stock RB20det. Congratulations. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5292499 Share on other sites More sharing options...
SimonR32 Posted June 14, 2010 Share Posted June 14, 2010 I need my brain looked at, we were looking at the graphs trying to work out why the car had a wierd curve (laggy and not making enough top end power) Worked out I had f**ked setting the cam gears, will get them set again (they are 4deg out on inlet and 8 out exhaust) and hopefully retuned later in the week Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5292741 Share on other sites More sharing options...
hypergear Posted June 14, 2010 Author Share Posted June 14, 2010 Hopefully every thing works out and your car makes more decent good power. Did your tuner take advantage of the wastegate controller? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5292777 Share on other sites More sharing options...
SimonR32 Posted June 14, 2010 Share Posted June 14, 2010 (edited) Stao, he didn't need to... Was holding boost at pretty much any level through out the revs. Hoping for at least 30odd hp with the cam gears fixed and a whole lot more response. Can't believe i made such a stupid error haha Edited June 14, 2010 by Cerbera Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5292789 Share on other sites More sharing options...
Scradly Posted June 15, 2010 Share Posted June 15, 2010 Your a retard. Good to see the old faithful Made some power to spin one up. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5293066 Share on other sites More sharing options...
hypergear Posted June 18, 2010 Author Share Posted June 18, 2010 Some updates. I've made a new type custom turbine wheel aimed for power incensement with OEM turbine housings. Its expected to gain HP by roughly 10%。 Let me know if you are interested to try them out. I will pay for your tune at Dr.drift. You must have a fully working car with all supporting mods including ECU, injectors, Z32 AFM, 3inch turbo back exhaust and a metal intake pipe. Also I want to make a note for people who's currently running this type of split dump pipes: First of all the divider isolates the internal gate area which the gate flap does not open to a full 90 degrees. This result boost creep issues. Diagram not up to scale, just give you a basic idea of what happens. 2ndly the inner diameter is 2.3 inches with the split pipe plumbed back. Factory dump has 2.5 inches inner diameter. In another word factory dump would flow better then above, it will create exhaust flow restrictions resulting high back pressure and high exhaust manifold temperture affecting overall power output. For the best results please run a 3inch turbo back pipe or a bell mouth dump with 3inch front pipe. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5300721 Share on other sites More sharing options...
GTR_RB26TTS Posted June 18, 2010 Share Posted June 18, 2010 (edited) Tthe divider isolates the internal gate area which the gate flap does not open to a full 90 degrees. This result boost creep issues. 2ndly the inner diameter is 2.3 inches with the split pipe plumbed back. Factory dump has 2.5 inches inner diameter. In another word factory dump would flow better then above, it will create exhaust flow restriction, Please do run a 3inch turbo back pipe or a bell mouth dump with 3inch front pipe for high performance applications. What you have posted above is totally incorrect. That product works fine, there is no exhaust restriction in the way you describe at all. Also as the wastegate gases have been split off, the WG pipe does not need to be as big as the dump pipe. As you can see from here: The Skyline turbo wastegate flapper does not open the way you have shown in your diagram at all. (R33 & R34 are identical) The flapper opes to a perpendicular end, rather than a parrallel one as your little diagram has shown... As a turbo retailer... I'm shocked. Edited June 18, 2010 by GTR_RB26TT Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5300741 Share on other sites More sharing options...
hypergear Posted June 18, 2010 Author Share Posted June 18, 2010 That was just a basic diagram so every one can understand what happens in there. Diagram is not upto scale. A 2.3inch pipe does not flow any better then a 2.5 or 3 inch pipe. Simple as that. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5300746 Share on other sites More sharing options...
GTR_RB26TTS Posted June 18, 2010 Share Posted June 18, 2010 (edited) Does not matter what it is, fact is the diagram couldn't be more wrong if you tried. What you are saying occurs, and what actually occurs are two different things unfortunately and misleading/incorrect. The wastegate flapper is not impeaded at all, that is cold hard fact. Users are being mislead by that diagram - you should delete it. Edited June 18, 2010 by GTR_RB26TT Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5300753 Share on other sites More sharing options...
hypergear Posted June 18, 2010 Author Share Posted June 18, 2010 I'm not going to argue with the interpretation. This issue have been arose before, This diagrams explain the very nature of the problem. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5300770 Share on other sites More sharing options...
GTR_RB26TTS Posted June 18, 2010 Share Posted June 18, 2010 Of course you not - it cannot be argued and hence you have now removed the inaccurate information that should never have been posted in the first place. The diagram you removed had zero impact on the situation, you would not have removed it if it were correct Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5300788 Share on other sites More sharing options...
Checkbuzz Posted June 19, 2010 Share Posted June 19, 2010 Of course you not - it cannot be argued and hence you have now removed the inaccurate information that should never have been posted in the first place.The diagram you removed had zero impact on the situation, you would not have removed it if it were correct Stao has a hell of a lot of cred around here and is very generous with his knowledge and time helping people on these forums. He is also an expert on turbo's with valid point and you are just an annoying, rude NOBODY. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5301117 Share on other sites More sharing options...
GTR_RB26TTS Posted June 19, 2010 Share Posted June 19, 2010 I rarely post, however I do read a lot and have been playing with turbos for 10 years myself. The diagram I was questioing has now been removed, so sadly, you do not even know what you are commenting on. I am not for one second saying Hypergear does not know what is going on. However at times some of the information provided is just straight up incorrect & wrong. Something you would not expect from such an expert, last nights diagram was another prime example of this. If you saw what was posted last night, you would have your heads in your hands as I did last night viewing it. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5301149 Share on other sites More sharing options...
Birds Posted June 19, 2010 Share Posted June 19, 2010 Although I'm not sure what specifics you two are arguing about, Stao is correct about those split dumps jamming the wastegate. I had one of those split dumps on my car and it actually ruined my actuator diaphragm, dangerously gave me unlimited boost too. I disconnected actuator and moved the wastegate flap by hand...it only had 45 degrees of movement and kept getting stuck on something, which I thought was the pipe divider/seperator. Removed that and it was still getting stuck...turns out the wastegate pipe wasn't lining up properly and wasn't big enough. I die grinded the shit out of it, short of breaching the welds that hold the pipe onto the flange...and only then did it open up to 80 degrees. This STILL gave me boost creep (I run standard 7psi boost). I ditched it and got a custom 3 inch bellmouth made up, never had a boost creep / overboosting problem again. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/40/#findComment-5301285 Share on other sites More sharing options...
