You get full boost by 4300RPMs with RB25det using .82. It pulls lot harder.
If your purposes of buying this turbo is for mild power street use the .63 is fine, But it does get really hot under high boost if you use it for drifting or tracking.
Another small update:
Still remember this ATR43G3 unit with .82 turbine and .70 comp?
Got it dyno tuned today, car mad 298.5rwkws on 21psi with miss-fire. Only done 2 runs, car miss-fired very bad after, we changed plugs cleaned coils and nothing helped. I will give another try with splitfire coils in few weeks. I didn't grab the dynosheet this time. But dyno footage with 3 people in the boot is worth to look at:
(click on photo below to watch that video footage)
Also my engine comp shown:
130, 125, 125, 120, 125, 119
Next run will be with a new forged engine :miner:
nice power how much for the turbo? and what mods does it require to bolt up
Peak power was around 7000RPM. Check the 2nd run with people in the boot.
Power rise till red line, the curve is very similar to the 268rwkws run with restrictive intake and the 316rwkws run on with the sil180.
car was not strapped with wheel spin, Reved to 7000RPM as usual.
Next run will be with a new forged engine :)
These are the ones i wanna see more of :) 0.82 has a better power torque balance than 0.63.
I think this turbo is the same as my ATR28g4. Getting slightly better spool now with my alternator changed. Hitting 1 bar just after 4000rpm with no boost controller. 10psi Actuator with heap of preload
Further updates:
Apart from turbochargers our engineers are also dedicated in to engine building, how ever I'll not provide this service to the public. I will show every one how it’s done and costs involved. Any useful advise is welcomed.
Primary goal:
This engine will be used for our turbocharger evaluation pusposes, My goal is 350rwkws.
This engine will be built with stock cams using forged pistons only, so Power vs Boost generated from it would be identical to any other healthy standard RB25dets.
Engine:
96 model RB25det engine bought from local wrecker.
An hour later its in bits:
Cracked piston in cyc 6. But bore seems to be in ok condition
I’ll be using forged CP 20 thou over sized RB25det pistons with rings and pins. The piston set cost $1150 AUD.
Engine block's been sent away to Reflex engine services. Its going to cost $260 to re-bore all 6 cyc with block thermo bathed. Engine head cost $250 to trim and bath.
Also for people whom owns a pair of CT12a Powered 1JZ Soarers. We can high flow them to 2860rs Disco CHRA specifications in sleeve bearing:
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
