Torques Posted July 13, 2010 Share Posted July 13, 2010 You are actually moving an engine from the wrecker in the trunk of a Skyline?? ons only, so Power vs Boost generated from it would be identical to any other healthy standard RB25dets.Engine: 96 model RB25det engine bought from local wrecker. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5345287 Share on other sites More sharing options...
Torques Posted July 13, 2010 Share Posted July 13, 2010 Hi! Would you be able to supply compressor maps for your high flowed turbos? Cheers, Andrew Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5345294 Share on other sites More sharing options...
kwickr33 Posted July 14, 2010 Share Posted July 14, 2010 (edited) More updates? Edited July 14, 2010 by kwickr33 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5346102 Share on other sites More sharing options...
hypergear Posted July 14, 2010 Author Share Posted July 14, 2010 The compressor map with the standard high flow would be identical as: http://www.turbobygarrett.com/turbobygarre...60-15comp_e.jpg Since its running the same size wheel in same size housing. Further updates: The ARP bolts, Bearings and full Gasket set cost $691. Engine come back horned and cleaned ($535). The job was abit rough thou, I spent hours buffing out the left over residuals from previous head gasket, Which I paid to get it cleaned. Any way: Engine block with pistons back in and head assembled: Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5346122 Share on other sites More sharing options...
kwickr33 Posted July 14, 2010 Share Posted July 14, 2010 (edited) Nice. Drop in a set of Tomei Pro Cams, 6 boost exhaust manifold, and a Greddy inlet manifold. Should push towards 400rwkws. Edited July 14, 2010 by kwickr33 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5346208 Share on other sites More sharing options...
hypergear Posted July 14, 2010 Author Share Posted July 14, 2010 Well original goal of building this engine is not for that wow factor, I just need a very solid standard engine to evaluate max power out put on 98 fuel for all high flow profiles and bolton ATR43s. So Power vs Boost vs RPM would be identical with the same turbo on any standard RB25dets. This is also a None Neo motor, Neo engines would pickup better power and response. Results with fully moded head, cams, and manifold would be deceptive as no one else has the same mod. But I will get them to run with race fuel and Nos after the evaluation for abit of fun . Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5346553 Share on other sites More sharing options...
l0WRB Posted July 14, 2010 Share Posted July 14, 2010 looking good Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5346580 Share on other sites More sharing options...
GeorgesR34 Posted July 18, 2010 Share Posted July 18, 2010 Hi Guys, I'v just bought a fully stock R33 of JSA 2 weeks ago. I'm looking to get me turbo high flowed and make some power. Can you give me a list of recommended mods? Cheers. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5352018 Share on other sites More sharing options...
l0WRB Posted July 18, 2010 Share Posted July 18, 2010 Link G4 Ecu hiflowed turbo 550cc injectors 3" dump/exhaust gutted cat intercooler bosch 040 fuel pump 5puk exceedy clutch and wind that up to 20psi and watch the figures climb haha Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5352075 Share on other sites More sharing options...
hypergear Posted July 18, 2010 Author Share Posted July 18, 2010 Hi Guys, I'v just bought a fully stock R33 of JSA 2 weeks ago. I'm looking to get me turbo high flowed and make some power. Can you give me a list of recommended mods? Cheers. If its just been complianced there are few of things to be done: 1. Install a front mount cooler (we can supply). 2. Install a strong clutch (recommend Xtreme clutch kits at Ace Brakes ) if your is stock. 3. Install a full 3inch turbo back exhaust with a honeycomb cat. (JSA are Xforce dealers they should have plenty). 4. Get a set of 550cc / 700cc injectors (Try Cjmotors). 5. Get a Z32 AFM. Try Japart or see if JSA's got one. 6. Get a 3inch metal induction pipe made up (Try Glenroy exhaust) and get your self a good pod filter. 7. Get a PFC or Z32 ECU with Nistune chip (You can get that done at my recommended tuners). 8. Bring pass your stock turbo and have a chat, we have few different profiles and turbine housings to choice from. 9. With few hours of Dyno time at Dr.drift or Status your car would be pretty sweet to drive. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5352181 Share on other sites More sharing options...
hypergear Posted July 23, 2010 Author Share Posted July 23, 2010 Another update: This is a OP6 high flow that we did for a customer's R33 (none Neo engine) earlier using our updated turbine wheel. It made 241rwkws at 15psi full boost by 3450RPMs with 98 fuel. I'm pretty happy with it, Dyno sheet showing results of tuned maps before and after high flow. It made more power every where without more lag. The other thing that I'm pleased with is the power curve which sits lot more gradual instead of linear. So the wheels will be able to convert lot more of those energy onto acceleration momentum. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5362922 Share on other sites More sharing options...
33gtst Posted July 25, 2010 Share Posted July 25, 2010 Stao, The dyno sheet above is running a 44mm external wastegate off the exhaust housing with boost controller. Sam. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5364502 Share on other sites More sharing options...
baby34 Posted August 1, 2010 Share Posted August 1, 2010 Hi mate, am interested in a Hi Flow Turbo.. looking at running around 230rwkw.. How much does it cost to Hi-flow my current turbo I got a gT-t r34. & do i take it to my mechanic for a straight bolt on? I have a new front mount intercooler, Clutch. Do i need an ECU? Whats the cheapest ECU I Can get? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5378593 Share on other sites More sharing options...
hypergear Posted August 1, 2010 Author Share Posted August 1, 2010 The cost to high flow is $960 inc GST and braided oil feeding line. Every thing bolt back on. The cheapest ECU option would be getting a Nistune ECU installed and you need a set of at least 550cc injectors and a Z32 AFM. Will get you 230rwkws with 14psi of boost. With The Nistune ECU you can order direct from Matt on: [email protected] its $350 installed. Some of your local tuners can also install it as a package with the tune. Also some update with my engine build: The engine build has been complete and it is now back into the car. How ever it floods it self every time I crank. I guess I have to toll it to Sam to play with the map. Not having much luck with it this time. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5378596 Share on other sites More sharing options...
YF34R Posted August 2, 2010 Share Posted August 2, 2010 Hi Stao, i been thinking to Hiflow my turbo for a while now, just wondering once u guys Hiflow it do i need to upgrade my ECU straight away or car i still drive on it till i get around to buy my new ecu thanks Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5379394 Share on other sites More sharing options...
Trozzle Posted August 2, 2010 Share Posted August 2, 2010 I would assume you shouldn't have any problems driving it around on low boost with standard ECU for a while. Though having said that, it comes with a high pressure actuator, so you will have a lot of trouble driving it around without overboosting. I will be receiving mine soon, and will need to drive it on stock ECU to the tuner after fitting. I'm not looking forward to that part lol. I'd recommend (as I'm sure others will too) to just save up some more, and get it done at the same time as other necessary supporting mods (injectors, fuel pump and ECU) Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5379424 Share on other sites More sharing options...
hypergear Posted August 2, 2010 Author Share Posted August 2, 2010 Hi Stao,i been thinking to Hiflow my turbo for a while now, just wondering once u guys Hiflow it do i need to upgrade my ECU straight away or car i still drive on it till i get around to buy my new ecu thanks Once turbo is high flowed you can still run about 10psi with stock ECU and 98 fuel. There will still be a very noticeable difference in power and torque. It is recommended to go for a aftermarket ecu some injectors and etc to get the full potential of your car. Some updates from yesterday: Engine's build has been completed. Taking the old engine out with respect to its 6 month service. New engine is dumped in, alone with a evaluation subject: OP6 high flow How ever the engine fouls plug on crank. Tolled it to Dr.drift today and hopping for the best Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5379504 Share on other sites More sharing options...
Trozzle Posted August 5, 2010 Share Posted August 5, 2010 Stao/anyone who may know: I am intending on at the very least running this as my temp setup until I can get a hard intake setup made, will this flow 18psi through an ATR43G2 without causing restriction? 3" turbo inlet > 3" to 2.5" silicon adapter > standard R33 intake piping with 3" steel pipe mod to stop sucking closed > pod filter the 2.5" silicon after the turbo is my concern, but I've heard that it won't cause an airflow problem as long as the intake piping doesn't suck itself closed. Confirm/deny? Thanks Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5383514 Share on other sites More sharing options...
hypergear Posted August 5, 2010 Author Share Posted August 5, 2010 Here are 3x dyno sheets for your reference as stock intake system, stock intake pipe with metal insert didn't work. I also believe your friend Pat experienced very difference result before and after upgrading to 3inch metal intake with pod. His comments are in page 39. Results: 1. ATR43G2 Stock intake pipe with air box no filter. Intake pipe sucking shut. 2. ATR45 running stock intake pipe with metal sleeve stopping it from shutting with pod filter. (left) ATR45 running 3inch metal intake pipe with pod filter. (right) The sleeve insert run ended early as it not only restricting power, it did some thing strange (knocking?) and inconsistency in AFM reading. This run ended early. So please use a 3 inch or better 4 inch intake pipe with a good flow pod filter. Or at least use that for tuning. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5384399 Share on other sites More sharing options...
Just_Rb Posted August 5, 2010 Share Posted August 5, 2010 how have the silicon intake pipes shown themselves, any good? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/44/#findComment-5384565 Share on other sites More sharing options...
