Stao, what's the main difference between the G1 - 4? If I have the G2 0.82 and am making 285rwkw on 15psi, I would expect similar on 17psi as above. Not that it's a bad thing at all :laugh: just curious as to my results compared to the above.
I guess G1-G4 's all got different wheel profiles and rated differently in HP, Lower HP rated turbo will produce better response. How ever most of our turbos are engineered specifically to what a customer's asking for, so its not really following the guided specs.
The twicked ATR43G3 is running a 58T 76mm which was custom made, it seems to flow lot more air down low in a .70 comp housing. It is interesting because larger comp housings has shown greater lagness in my previous testings but it seems to make the turbo more responsive with RB25s.
I believe mine had a 58T 76mm from memory, but with only a 0.5 front cover... May be interesting if I end up going a RB25NEO to see results with either my 0.63 or upgrade to a 0.84
Need a .82 rear for the RB25det Neo engines. You will find the .63 is restrictive up on the top.
Little more updates. This is the result from Harey. from PU high flow with a R34 GTST. Its got abit of exhust and intake restrictions. Final run of 280rwkws @ 17psi 98 fuel.
Sheet:
As some of yous already seen from the public thread, This is our updated 21U R33 GTST factory turbo high flow profile.
I did read many posts in regarding to high flowing with the factory 21U RB25det R33 turbine housings. I did some testing in it with a modified exhaust wheel, I like to share this information publicly and I believe this is the absolute max this thing can flow.
I also managed to hold 20psi flat with that small housing using a wastegate controller and a high pressure actuator on 98 fuel.
The max power it managed was a stunning 297rwkws when its cold, with final run of 273rwkws consistent. The little sucker was burning red hot.
Sheet:
Video footage for all 3x runs are recorded:
I'm little bit concert with high back pressure. So this profile will not yet be commercially available after further testing and examination for component wear.
Why is the boost dropping off in the PU hiflow its 0.82 isnt it?
That would be from intake and exhaust restrictions and injector seal leakage. Also Trent didn't had too much time adjusting wastegate controller that night. Its getting back on the dyno tomorrow.
Yeah I am still sorting some things out. As Tao said lots more to try. We also just discovered the front injector is causing a boost leak so that will need to get fixed before any more testing. I will have more results next thursday.
We have a few more wastegate settings to try as well as dropping the exhaust as its suspected to be a bit restrictive.
That 279rwkw is actually at only 15.8psi so plenty left in it.
Its a bit different to Tao's demo car cause all these things are sorted and you get a direct comparison.
Fair enough look forward to the results.
Further updates:
This is the very first prototype of our Duel Ceramic Ball bearing turbo CHRA. Its running two air craft caged ceramic ball bearing cartridges in a fully CNC machined billet aluminum bearing casing. Its been then inserted into a GT28 bearing housing for water cooling ability. This turbo is oil and water cooled.
Short Video, span by a small compressor.
Above CHRA is made to suit a OP6 Rear housing for 500HP high flowing applications. Since OP6 housings are running short I will be testing it in a .63 ATR43 rear housing with a .70 Comp housing. Hopefully it works according to plan.
Big thanks for a anonymous member who've donated a OP6 rear housing for this project. We will be running it in a real OP6 rear. Looking forward to consistent 300rwkws.
If they test to work 100% you'll be looking to spending about $1900 to build in any of the brand new ATR43 units or around $1600 with Kai high flows.
Also The high flow page has been updated. 2x New high flow profiles has been added.
Standard high flow options using standard housings:
21U R33 turbo: 240rwkws
OP6 R34 Turbo: 260rwkws
Kai High flow using standard housings:
21U R33 turbo: 270rwkws
OP6 R34 turbo: 290rwkws
PU high flow using .82 rear housing:
21U / OP6 turbo: 300rwkws
Detailed information is at our website:
http://www.digi-hardware.com/rb25t3hiflow.html
maybe these are becoming a little bit more expensive because they are bolt on items ( i think ) ? but u are correct u can buy garrett items for far less but these are not bolt on i guess :(
looks good stao,but wow the prices r gettin really high 4 a custom built turbo? :)
GCG charge about the same for a bb highflow, I wouldnt say it is high for what you are getting.
Can pay less for a genuine Garrett turbo
I really doubt this.
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
