More update for the SS profile:
BP 98 Fuel, No boost controller, No wastegate controller 286rwkws @ 17psi.
Stao can you confirm specs of this turbo?
Is it the Billet 71mm compressor in RB25 SS profile?
How much would this cost with generic internal gate T4 rear housing?
I want to fit this to a 1JZ (2.5L) so please recommend turbo and housing, as states aiming for 280rwkw but very good torque and boost response.
The SS profile looks good. so that's compatible with a stock r33 turbo or a separate turbo all together?
also, is the HKS strengthened actuator compatible with your turbos after hi flow?
thanks stao there looking good
Ive bought the SS turbo off Stao as he plans to start with the next design and what not. I will be reporting all my experiences, dyno graphs and other data to him and I shall start a build thread about it!
Excellent news mate, I think its the better way for you to go. You were honestly shit out of luck with 2nd hand mismatched shit.
Will be good to see you finally sorted with a near bolt on alternative.
BP 98 Fuel, No boost controller, Wastegate controller wastegate controller set
320rwkws @ 20psi
I'm very happy with this results, Its not only as what appeared on paper, its made an very fast street car. boost comes in nice and early, smooth acceleration, minium wheel spin, hard pull till red line.
looks awesome for a local turbo option.
If I was in the market for a turbo Id be getting one of these.....
would be interested in the comparable cost VS a GT3076R. Bolt on of course. ie complete cost to bolt on ready for tune.
a custom gt3076r with ported stock nissan comp cover, avo .73ar 6-bolt rear housing, lines etc comes to around $2400
what would the ATR43SS cost, including all lines,bolts,nuts to bolt on ready to go?
result looks fantastic to be honest
For the 1JZ member: Rear adapting pattern of the ATR43xx can be made into a Vband internally gated or 5 bolts pattern for external gate.
Today I've removed the ATR43SS and replaced it with a ATR43G3 with .70 comp and .82 FNT tri-nozzled rear.
Haven't had it tuned, driving around gently, it seems like it comes to 0psi on 2nd gear by 2500RPMS and pulled hard to red line.
If I call the stage of where the turbo comes on "song" (that spool sound before gone into jet sound just before 0psi), then this turbo seems to be on song as soon as accelerator is pressed, very good response and very conformable to drive on road with lot of useable power and torque band.
With larger housings its really torquey and smooth, I think this is another brilliant road turbo.
comparing to the current ATR43g3 .82 .70, The FNT version picked up lot more mid range with far better response, I will find out if its going to affect top end or not on Tuesday.
In comparing to the SS I’ve just removed, the SS produced a lot sharper sort of acceleration, while The G3 with FNT more felt like power increase due to increasement of engine cubic size.
Price wise the RB25det Bolton SS with billet comp and FNT turbine, I will need to charge $1900 including GST, oil line and high pressure actuator to cover up all the extra labor spent in manufacturing. The Vband version is $150 cheaper.
The Standard ATR43G3 with FNT cost additional $200. Once dyno confirmed, any one with a standard .82 ATR43Gx / PU high flow can send theirs in for FNT integration at $200.
I've made a 3 nozzled ATR43G3 .82 turbo, installing it tomorrow. By re-directing air to a more efficient spot improves the current response and driving ability, in combination with large size housing it should produce possibly better power with greater torque.
If works it can change the current ATR43 .82 and PU high flow's power and boost behavior, making a powerful car lot more street friendly.
Installing it tomorrow, will write up some DIY instructions.
what does 3 nozzled mean/refer to?
Please PM me when this turbo is available at your usual realistic prices. $1900 is not far from purchasing one of the new borgwarner EFR turbos (about $2200 landed for state of the art tech).
I do understand that the cost of tooling and machine work needs to be accounted for yet believe the price is still a touch rich for my liking.
The additional funds were paid into labor and materials in manufacturing, its not cheap when every thing is made in Australia with qualified engineers. Plus the turbo it self is engineered to be a bolton solution, so even been $1900 you are saving lot more then $300 at the stage of when its running.
Only way I can see it been cheaper is to send out all of our machinery work overseas, its a hard ethical decision I'm tempted but not yet welling to make. Cheaper solutions will be announced when available.
This is for people who's asking to see the fuel and timing map for ATR43SS-2 Billet FNT turbo.
(hope I got the nistune software to read correctly)
Timing map:
Fuel map:
Stao what size is your turbine wheel in the ATR43SS??
I would like to see the billet 71mm compressor mated to a 55-60mm turbine with high flow (low trapping effect) in a compact housing with FNT.
Please elaborate on SS specs (to help justify costs)
Well you don't need a .82 rear for 230rwkws. Its more made for high torque 300rwkws applications, that would make a laggy 230rwkws on road. I think high flow based on stock R33 turbo would be your best option for a fast street driven 230rwkws.
Also with the ramp rate, you won't really know it unless its been addressed. Few obvious tails I've noticed with the Dyno pack dyno that I've used:
Notice the high lighted dip and flat bit, you will find that with 12 sec ramp timing on stock Rb25dets. I will do runs on both ramp speeds from now on.
Funny because I also have the dip and flat bit on my graph but it's definatly done on a 9sec ramp rate... When we did a 12sec ramp rate it also moved the graph a whole lot more left than yours moved so I don't think picking the difference is as simple as you have portrayed!
Also I noticed how you are now putting on STP correction which gains a lot of power, the run below only makes 388rwkw without STP correction on.
Edited by SimonR32
There could be more tails, I'm only referring to Status dyno with 98 Fuel. Also high ramp also makes exhaust side hotter, which means large famed turbos will show affect of been advanced, also not sure of effects of E85 fuel. Note 12 sec run vs 9 sec run based on a KAI R33 2iU high fow, its showing same trace:
Don't know what those corrections are maybe Trent can add in some input. How ever the SAE labled dynosheet above produced more power then STP, probably other way round.
Dyno tune didn't go very smooth today. car's ended up with ignition issues after few runs. need to sort out its issues and do another try.
This is a short 9sec run based on a .82 rear FNT turbine housing ATR43G3 with .70 comp internally gated on 98 Fuel with little miss fire. in comparison with a standard .82 ATR43 based on the same ramp speed.
Note how the FNT made more torque down low, held torque longer up on top and held boost lot better.
Above only captured engine behavior in 4th gear paddle to the floor. Big improvement in road driving ability, boost comes in lot earlier in lower gears, lot faster off the lights or 0 to 100KMs acceleration. Most important, this nothing then massive pull tyre spinning every where behavior has been replaced by very solid and smooth acceleration with almost none wheel spin specially in 2nd gear. Very strong increasement of Gforce as RPMs engage red line. Overall a lot faster road car.
I’ve got few more drawings of FNT turbine setups, will try them out in later stages.
Next to come is the an smaller version of SS that is made for 250rwkws, and hopefully the new parts replaced (CAS, Ignition model, one coil pack) stops this miss-firing issue.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
