The stock one can externally vent too, if you stick a grub screw in the little bypass hole...
Why don't you just block it off until the intake is fabricated properly?
Can't be stuffed taking the car to exhaust joint and they wanted to charge me $350 for a intake pipe. lol beside I've already bought the part.
add:
Good to hear mate, and that's a very good price for everything isn't it? ;)
Yea man thats GTRS's performance with better response at half the cost. fken nice to drive. can't wait to get it boosted and tuned.
Edited by petero'nell
I really hope the prototype works then we will be concentrating in the GenEses development, the principle on that is having a turbo car idle at 1~2 psi based on a 500HP turbo, so people can take off and drive on boost all times. Making "turbo lag" history.
I see no practical way of this being possible. This would be an amazing piece of technology. How you can create positive boost on idle with the throttle shut is beyond me. It doesn't sound possible. How do you create a turbine structure capable of creating positive boost from the exhaust flow of an idle engine? The SS2 Ive got is almost like it is off when there is no load on the engine. I can rev up to 4k and control my foot to create nearly no pressure at all and when I plant my foot it comes on like a switch, but having something always creating pressure needs an opposing force.
And now I am getting jealous of this new turbo you have built which could see 280-300rwkw with stock turbo response :( Can my turbo be modded to suit?
Edited by SargeRX8
Sargerx8. To easily explain what you don't understand put a boost gauge before your throttle body. You will have substantial boost it just isnt getting to your plennum/boost gauge. Thats why it appears to come on so quick.
I'm not sure working to have a turbo boost on idle would be a good thing. Off boost driving is actually great, not something I would personally want to give up.
I'm not sure how successful these turbos would be in the wider community....
Its definitely not something for all users but there will almost definitely be a market for it out there.
If he can make something like this which can be somehow controlled, by a valve or something, to switch off this feature, I think there would be no one driving a skyline without it. If you can make something happen, you can control how it happens, when it happens and why it happens. A car engine was built ground up, everything that a car can do can be controlled in literally every single way. Boost, fuel, air flow, knock, lights, wipers, etc. If his intentions are to control it using something from the engine flowing or pushing something on the turbo, something similar to a wastegate, or electronic gate could control it to switch it off when it is not needed.
I still think its impossible.
Edited by SargeRX8
But that isn't the engine boost level so it's irrelevant. The throttle body is causing the restriction and that restriction is causing positive pressure, potentially you could open the throttle body and the engine would see no boost.
Stao's statement was incorrect and misleading
That 2 psi is pre-throttle body pressure. So when throttle is given the car launches with 2 psi of boost and build up from there. Still thinking about it, at this stage its 55% looking possible.
Will it be controllable? Can it be turned on and off or a fixed feature?
I dont understand the theory... Pre-throttle body pressure means nothing? As Simon said, the butterfly is the restriction so measuring boost against that doesn't mean much. When the throttle body opens and the motor needs airflow, the positive pressure will drop. It's about volume of air, not pressure? I fail to see how youre going to create boost at idle when there is no load.
That said, if it can be done then I'm very happy to be proved wrong. I just don't get it.
Still thinking about it, As soon as throttle opens the intake pressure drops, so pointless of building up pressure pre-throttle unless its lots of pressure. Need some thing spins quickly, makes enough pressure to fill the drop with bit of room for positive boost. Then switch it self off when turbo comes on.
That didn't work for me, the stock bov just kept on getting sucked open by vacuum.
The standard BOVs have 2 diaphragms as far as I know, the BOV's upper diaphragm will be sucked up when under vacuum, which lifts the whole piston setup upwards and allows the BOV to breathe through the return pipe. Then once manifold pressure is no longer under a certain level of vacuum, the spring inside the upper chamber of the BOV will return it to a closed position. This is why people always point out that stock BOVs (GTR included) are open on idle, and the reason why I now need to buy an aftermarket one - mine's running atmo hence breathing unfiltered air :stupid:
I dont even understand what he is proposing to do
Imagine a T25 from a CA18 on a 6L V8.
The second you open the throttle you will see boost. Stao wants to make something like that which still works like the turbos we currently use there after. Eliminating the wait for power to come on, and has quoted he wants it to be a 500hp item.
Sounds good on the surface, yet as stated most of the more experienced users would appreciate some level of lag. But who knows, maybe the technology can be fine tuned further so that there's more leeway than currently being discussed.
I cut my factory BOV open and there is just a diaphragm, one spring and one piston. Once the bay pass whole is blocked the diaphragm gets sucked upwards and the piston opens. I sort of got it to work by placing a one way valve into the pipe that connects to the bov to inlet manifold.
As for the GenEses, I'm planning to use a high powered electrical motored duction fan working with a turbo. Can be high voltage external batteries based. The Fan only operates till the turbo takes over. Depending on how long the battery pack can last, we can wire 2 or more battery packs and have some thing switching between the battery packs when one is running low. That battery will have a 12V charger charging it when laid off. So a super responsive high efficiency turbo is required as a base for this setup.
Above is just a theory thing at early stage there will be lot more in it. Might or might not work and the finished product might be too expansive to sale. But would be good project to give a shot at proven its possible or not possible with what we've got.
There are lots of failed earlier examples that I've already known, so no need to post that. But do post constructive ideas and tell every one what you think that might make this work.
So electric supercharger at low revs, or it will assist the turbo in spooling up?
I have an idea, could you drive the turbo from the crank (like a supercharger) but use some sort of sprocket so that if the exhaust wants to turn the shaft faster than engine speed it can without issue? So basically it only saps energy from the crank at low engine speeds when the turbo wouldn't normally be spinning that speed, when there is enough exhaust energy the turbine takes over and spins it.
How does that sound? I don't know how you'd route the drive from the crank to where the turbo normally sits but I'm sure with enough money it could be done.
Edited by Rolls
His idea of the electric fan is a good idea. I was thinking about having it belt driven yesterday when I read the initial idea. I don't think it will work. These turbos spin at 100000krpm. Our engines do what, 7? On idle the turbo will already be outspinning the engine...
There are these wonderful inventions called gears... how do you think super chargers work?
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
