I have been thinking though. The stock turbo was set to 13/14psi but in cold weather had no trouble pushing over the boost limit though my intercooler and it's a much smaller turbo.
One thing to note on my current setup is my actuator gets it's boost feed from the cold side of the intercooler so technically the turbos wastgate should be shut tight when my boost starts to drop.
Rolls - that's why I'm here, to see what people have on their cars. I think I should actually use what ever stao has on his test car as it "should" give similar results.
Yes but your new turbo is now flowing much more at that given boost pressure.
You should hook the actuator to the nipple on the compressor, why on earth are you running it from the IC?
Re using the same IC as him that is a really good idea, at least you are removing another unknown that way.
Edited by Rolls
There isn't a nipple on the compressor. The fitting that used to go to the charcoal canister was the closest fitting I found.
FAIL!
This will be half your issue... Run it from the compressor cover or the cooler piping BEFORE the intercooler
that is weird that it doesn't have a nipple on the compressor housing, are you using one of HGs aftermarket housings? If so how does he set them up?
If anything though running the hose from anywhere else should cause boost spiking, not bleeding off.
Edited by Rolls
I think its best to send it back and swap for a FNT G3, I can give you my 330rwkws nistune map, load it in and see if that changes boost and power behavior, That turbo should also suit your driving style better.
Ok I'm sick of playing this game now. Now it only makes 16psi and nothing has changed
You're changing it's symptoms, that's a good thing. Just keep working through it.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
    • Yup. I actually just blew my turbo. LOL.  should have checked this thread before today. i also have no boost solenoid. so it should be...one line from wastegate to turbo inlet, and a T somewhere in that line that connects to the wastegate return pipe?
    • It's recommended, however I can assure you a good amount of people don't bother. FWIW, the OEM battery lasted 4.5 years and I changed it prematurely too, I reckon could have stretched it to 5 years.
