Haha good cause ur post hurt my head. :P
I learnt something last night. I was always under the impression the duty cycle refered to the duty during the pulse width and the injector was PWMd during this time. Turns out it is just simply pulsed on and the duty cycle refers to the % on out of any given time window.
I feel stupid, assumed it was more complex than it really is.
no but if its tuned really close the the injectors max and something happens that needs some more fuel (hit r&r maybe) then you won't have enough headroom left
then you run lean and boom
Whats with teh new "Kai" labelling on some of the turbo's on the website? you can get an op6 Kai highflow or a normal one, whats special with the kai?
I understand that the injector is providing its maximum flow at 100% and that it will run lean if you continue to introduce more air. I'm asking more about the timing of fuel delivery the closer you get to 100% and it's effects
Over 80% the fuel injector is basically static anyway so you don't continue to get a linear increase in fuel delivery over 80-90%. You ultimately don't want to be running much higher than 60-70% duty cycle.
Rolls no offence but based on your comment this afternoon you don't know what you are on about when it comes to injectors. no.gif After the pulsing comment I thought you would have left it alone yes.gif But all good anyway... tongue.gif
My car has 910cc injectors and have hit 68 percent at a 11.5:1 afr. From blokes that know, I have learnt that 85 percent is the max for injector life as well as fuelling reliability. Clearly they can be run higher but don't last as long.
We've engineered a new turbocharger for a RB20det aimed at responsive 200~230rwkws. how ever I don't have a Rb20det powered vehicle for testing. Let me know if any one's interested of trailing.
Evaluation units are $1100 inc gst and oil line, based on the condition that a dynosheet must be provided with the vehicle running its peak efficiency after installation.
The car needs to have the following mods installed or to be installed pre-dyno tunning.
Programmable ecu
FMIC, Free flow exhaust.
injectors would be perferred.
Local members are perferred.
there are 3 units made. Will refund at purchase price if they under perform.
Programmable ecu
does Kai mean PU?
It is true though. I just confused the time period duty cycle was talking to, the behaviour of the injector is the same. After 85% ish it doesn't get time to close properly and is essentially completely open.
does Kai mean PU?
No. Kai runs a much larger turbine wheel they makes very close power as the PU high flows how ever it feels pretty laggy on road. Unless customers really want to use factory turbine housing then we would recommend PU high flow option better.
Pu runs our own .82 turbine housing with factory compressor housing. Its like a small trimed (56T) ATR43G3 with factory comp housing. Standard ATR43G3 runs 58T comp wheel with a .70 comp housing.
i think this info should be on your website
maybe a turbo selection guide would be useful too
i've been trying to help out another stagea owner down here with what to get (he has already emailed you)
i'm probably going to go down the same path as him too
Tao is it normal to hear like the front compressor wheel spinning? I never noticed it but now I can hear it, sounds exactly like my old high flow. Very feint but if you listen for it you can hear it...
Should make a tinny sound which is from air travelling through the pipe and inlet of the turbo. pretty normal. How ever, your compressor wheel had some stone chips from object sucked in I probabaly want to check it out and make sure its still within balance range.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
