I had one problem with mine. Was told by stao the water feeds on the turbo were 14x1.5 so wasted nearly $50 on speed flow fittings
Rest was fine. Was a atrg3 .82
So should everyone be checking the clearance between the dump and aircon pipe? So if there is not atleast say, 30mm clearance (5 bolt exhaust flange has an extra 25mm over stock now) , then you need a different dump pipe. Is this correct?
Mine had a little bit of clearance (~20mm) which i didn't notice. Ended up frying the tube lol.
Harey - there is nothing wrong with my install, unless you want to blame me for a ring not holding compression. I will have an engine in and dynod before Christmas if I can.
Except for dodgy boost signal and you running 25psi when it was tuned to less than 20psi?? The better the turbo the worse damage you will do from running way above tuned boost levels!
In no way do I doubt other people results, I'm just disappointed at the recommendations(not just about hypergear)I have received considering how things have gone, honestly I think I received a faulty actuator, and I still don't feel that any damage was done by myself, it looks more like the engine was never run in in Japan.
No just considering there is no damage just low compression, either the ring had never bed in or it just wore out. And considering the rest are fine it makes more sense that it didn't be in.
Good to know I'm not the only one. The way my install went I think having a known turbo (garret/hks) is worth the extra few dollars, fair enough I am yet to see if the hypergear can actually make any power but before Christmas I will have all the information/dyno sheets to know if stao will be receiving my turbo back.
cool, so I guess you think everyone that rushed out and bought GT30s back when the write up hit SAU returned their the turbo if they didn't get 300kw?
That was the aim of that turbo on the RB25, yet if you look at real world results there is a 250kw result for every 300kw result with seemingly the same effort applied. In your eyes I guess they should all get refunds!
I should blame a supplier for my blown SR, it was running tuned for 7 years then the day I put on their catback it blew! Those assholes sold me a faulty pipe. Sound funny? Actually its exactly what happened to you. I put something on my car and thrashed it while it wasn't tuned for it. Boost spiked, it went way harder, god knows what else, and cost me a healthy motor. My faux pas as I didn't think a simple catback would throw the tune out that much. On my life one lap around the block, pop.
Its no hero story, just consider it though. Its entirely relevant to your case, ive read all your posts, including those when ur motor was untuned in the stages area.
I didn't mean for a refund, I would just like him to have a look and see what's going on.
Yes I drove my car around with a 3500rpm red line for a few weeks, I didnt think it was that big an issue, clearly Nissan motors aren't as strong as the Toyota engines I'm use to owning.
you couldn't source a proper boost feed for the actuator..but you are qualified to say there is no damage? 2 days ago you couldn't get the head off, a few weeks ago you thrashed a motor tuned for 14psi when you were running 25psi......but it is Nissan's fault?
why does anyone help this idiot?
1. Nothing wrong with where I had the boost feed, people had suggested getting a boost feed from the manifold :/. That is stupid.
2. Sorry for not seeing an invisible bolt.
3. Tuned for 22psi dropping to 14, so the 3/4 psi spike isn't a big issue in my point of view. I wasn't holding it wot to redline, was just creeping it to see if boost was holding.
4. I drove an untuned 35year old turbo celica with a 7psi boost increase for 4 years and never had a single problem.
Reading your steage section posts you've mentioned that you were chasing a RS4 GTR Stega with new turbo fitted and "just" got beaten. I'm suspecting you've blew your motor long before it got on the dyno, and the dyno tune plus all the threasing after just hurt it more.
Thats the thing about forums... Cant delete your old posts
This post sums up exactly how little you know about cars and how far you should stay away from them.
Well no one can fix up yesterday. He's main objective is getting his engine back together soon as possible. Below is what I've done building my test rig, follow that you should have a very solid engine with out spending heaps of cash:
I've rang around for the best prices on all parts I got:
1. CP pistons 0.5mm over sized from CJmotors
2. ACL bearings, ARP head studs, and full gasket set from MD spares.
I've paid about $1500.
Find a good engine re-bore service locally, get them to bath your engine block, re-bore your cycs refer to piston specifications, fit pistons and crank together as a short engine.
I've paid $650
If you are technically minded from there you can assemble it your self (mmmm not good idea). Or take it to a trust worthy workshop to have it assembled and dropped in.
I've paid $1000
So all up my rebuild cost just under $3200 and its been holding together well since. If you wish going slightly bigger in turbo I can help you getting that done free.
^ Hypergear always keeping it cool and willing to help you out.
You can't blame hypergear, you can't blame Nissan. You can't blame anyone. Your luck seems low. That option up there sounds pretty good. It really isn't hard to bolt the head back on and reassemble everything. Torque settings, set the cams, set the pistons, slap on the head, torque it up, manifolds, gaskets, studs, nuts, wiring, injectors, plenum, spark plugs, coils, turbo and your just about there!
Then again alot of guys here are blaming you for running 25psi. 25 psi will cause detonation but it isn't likely that one or two runs on this will KILL the motor.
Like I said in many other posts, if that cylinder bore is in good shape, replace that damn piston with a stockie and put it back together.
If there is no damage from detonation, pre ignition or lean out then chances are the 25 psi wasnt the issue for the motor. But without inspecting the engine i cant say for sure.
I can tell everyone is getting annoyed with littlecrash, but please don't start name calling,
Lilcrash have u started the rebuild process for ur motor yet.
No worth all the effort just to replace one faulty piston sarge, he might as well whack in a fresh set of forgies.
Please dont ever rebuild a stock motor with another 2nd hand piston.
Cheaper option would be to buy a second hand motor in known condition. You know it won't fall apart from poor workman ship like some rebuilds will, they have a proven track record and will hold 250-300 for many years if tuned correctly and never see detonation and are kept cool.
Honestly I would do that, you can get a s1/2 rb25 for $1000 if you look around, I personally sold a forged rb25 short motor for $1k with only 7000kms on it. Or you could fork out for a neo for around $2k which has some advantages, better head, better rods, newer with less kms.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
