Hypergear Turbochargers and High flow Services Development thread
The boost level seems to be affected by temperture. Just had few very hot days in Melbourne and the high pressure actuator seems to be holding 18psi instead of the 22psi when its cool.
Also shouldn't the engine run rough as with the tooth skipt on the cam gear?
I'll be looking at getting a hypergear hiflow done soon (as I'm only going to be chasing around ~230rwkw) and will have two turbos available:
a stock 45V1 VG30 ball bearing turbo, and a stock 45V4 on my 1996 series 2 RB25DET
Which one would be better suited for hiflowing with responsiveness being the priority?
Under that rubber pipe is just a white plastic hose that dumps condensation when A/C is on. The water comes in due to the car's acceleration momentum, get a rubber plug in that size then cut the center section out for that plastic hose. That would stop any water drain in to the cabinet.
Just had a look then and my a/c rubber pipe doesnt have any white plastic hose underneath? The whole top half of the black rubber a/c hose is burnt on mine. Couldnt work out where it comes into the cabin or how to put a rubber plug anywhere??
There is a white coloured hard rubber pipe under that rubber, water comes out of there when the A/C is on. Just make a plug from a bit of materials in Clark rubber for the frame and cut a hole in the center for that plastic pipe. That would stop any water drop draining into the cabinet. or just connect what ever bit of hose on to that pipe.
Is your dump a JJR item as well?
Mine is just flexi rubber hose, I can bend it and because the whole front is melted I can see inside and theres nothing white inside.
I cant workout where it joins inside the cabin.
Yes its a JJR dump pipe.
am interested in this as i will be going HG in a couple months. since my engine bay is stripped out ill try to get detailed photos up tonight so we can all have a good look :thumbsup:
That would be awesome if you can take some photos so we can all have a good look!! Hard to see with everything in the way.
Hey Sarge hows ur new intake pipe and lean popping issue? I just ordered me a set of YJ coilpacks, did u have issues with yours?pinch.gif
Lean popping wasn't an issue, I don't think. There was nothing there causing the lean pop and after fitting the AFR gauge it was showing that it was running around 13's which alot of have said will cause lean pop. I got rid of it by richening up the idle mix. Some people run 17.1 afr on idle and they put up with lean pop, I tried it and f**king lol no way in hell. It sounds like shit and the car feels like a rough v8 on idle. New intake pipe should be good. No more rubber or tight corner, a nice 90 degree 3" all the way through. It seems to have fixed my coming off boost stalling issue!
I had issues with them, I got a refund and got brand new OEM coils.
I found when I angled the bov return and pcv valve return towards the turbo inlet and away from the afm it solved my off boost stalling issue.
;) Its not so much the breather line as that is just under vacuum, no air gets pushed through it, shit is sucked through it, its more the BOV return which if when it releases the boost in the system, it hits the AFM, it goes into a fueling mode, adds fuel and stalls.
I think you hit the nail on the head with this statement. I remember u had a lean popping issue when u changed ur intake earlier, and maybe this was the reason above. Where'd u get those two little breather pipes with the rolled edges thats welded onto ur intake?
When I made my intake pipe, it was near impossible to run the standard BOV return so I chopped off the end and rather than throwing it out, I used it as the bung to weld on. If you are anal about it and want the edges rolled like that, buy another one that someone is selling (they are cheap) and cut as long or short as you need to line up with your bov return. I also ran a catch can so the hard return line for the oil side wasn't necessary.
so looks like if the hose gets blocked it will flood the car. also if its squashed or pulled in the wrong direction it will also get into the car. i might try cut it a little shorter and slip a bit of hose over the white tube and have it running down the inside of the black hose.
i cant see how the hose melting makes the water get into the car unless its blocking the hose when it melts
Edited by t_revz
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
