Hanaldo Posted January 9, 2012 Share Posted January 9, 2012 They won't help much with internal gates man. I held 20psi just fine with the previous Hypergear setup mind you. You should probably get the same setup as me so I can see how you go with the VIPEC Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181199 Share on other sites More sharing options...
skyzthalimit Posted January 9, 2012 Share Posted January 9, 2012 when are you hoping to have your turbo in if you decide? ill see ur result, and opion bout this LAG buisness b4 you see mine as my car is goin in 20th of this month to get wired at c-red as this engine is in a s13 so prob looking at april b4 i run this turbo. i hope to see fairly good results Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181200 Share on other sites More sharing options...
Hanaldo Posted January 9, 2012 Share Posted January 9, 2012 Heh, C-Red, same workshop that wired my engine. If you have a Neo motor, tell them you want the TCS enabled!! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181210 Share on other sites More sharing options...
skyzthalimit Posted January 9, 2012 Share Posted January 9, 2012 (edited) yeh i have neo engine, whats tcs? i gather its traction control tho Edited January 9, 2012 by skyzthalimit Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181216 Share on other sites More sharing options...
LANDSCRIBBLE Posted January 9, 2012 Share Posted January 9, 2012 They won't help much with internal gates man. I held 20psi just fine with the previous Hypergear setup mind you. You should probably get the same setup as me so I can see how you go with the VIPEC it looks that way. I am hoping my intercooler isnt too restrictive. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181224 Share on other sites More sharing options...
skyzthalimit Posted January 9, 2012 Share Posted January 9, 2012 what intercooler are you running? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181225 Share on other sites More sharing options...
LANDSCRIBBLE Posted January 9, 2012 Share Posted January 9, 2012 If i remember correctly its a trust greddy m-spec kit from an R32 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181260 Share on other sites More sharing options...
LANDSCRIBBLE Posted January 9, 2012 Share Posted January 9, 2012 when are you hoping to have your turbo in if you decide? ill see ur result, and opion bout this LAG buisness b4 you see mine as my car is goin in 20th of this month to get wired at c-red as this engine is in a s13 so prob looking at april b4 i run this turbo. i hope to see fairly good results Realisticly, probably next month it should be ready for a tune. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181319 Share on other sites More sharing options...
Hanaldo Posted January 9, 2012 Share Posted January 9, 2012 yeh i have neo engine, whats tcs? i gather its traction control tho Yeh traction control. Make sure they wire it up. They deleted mine and now it's causing me endless headaches. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181350 Share on other sites More sharing options...
skyzthalimit Posted January 9, 2012 Share Posted January 9, 2012 (edited) im running a no name intercooler so i wouldnt be worried bout a trust or gredy unit unless its one of those ones a tad bigger then a stocker , HANALDO are u trolling or serious u whant them to wire it even if it is in a s13 not r34? he swore everything would work as it would be, as if i was driving in a r34 ,ovisiously without traction control Edited January 9, 2012 by skyzthalimit Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181397 Share on other sites More sharing options...
Hanaldo Posted January 9, 2012 Share Posted January 9, 2012 It depends on what ecu you're using mate. I'm using NIStune, and the lack of traction control is wreaking havoc with the stock computer, making it pull fuel unexpectedly and things like that. Gives me a very rough power curve and makes it very hard to tune. They also didn't wire in my stock boost sensor, they replaced it with my EBC sensor and that's giving the same trouble. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181418 Share on other sites More sharing options...
10 4 Posted January 9, 2012 Share Posted January 9, 2012 Get a power FC Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181454 Share on other sites More sharing options...
rondofj Posted January 9, 2012 Share Posted January 9, 2012 It depends on what ecu you're using mate. I'm using NIStune, and the lack of traction control is wreaking havoc with the stock computer, making it pull fuel unexpectedly and things like that. Gives me a very rough power curve and makes it very hard to tune. They also didn't wire in my stock boost sensor, they replaced it with my EBC sensor and that's giving the same trouble. I mentioned. before that Im also running a stagea ecu on my R34 with R34 maps and Nistune - No TCS, hasnt caused me any problems at all except that theres no traction control. Have u tried swapping a diff working ecu Hanaldo? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181523 Share on other sites More sharing options...
rondofj Posted January 9, 2012 Share Posted January 9, 2012 Use a stagea ecu to test as it comes without TCS so shudnt create probs. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181526 Share on other sites More sharing options...
Hanaldo Posted January 9, 2012 Share Posted January 9, 2012 Way ahead of ya man, my ECU is currently with Matt at NIStune having the R34 image swapped with a Stag image. Shall see how that goes. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181537 Share on other sites More sharing options...
copycutter Posted January 9, 2012 Share Posted January 9, 2012 If i remember correctly its a trust greddy m-spec kit from an R32 That should be fine. If anything the G3 will be restricted by my cooling pro turnflow as the core is smaller. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6181610 Share on other sites More sharing options...
hypergear Posted January 11, 2012 Author Share Posted January 11, 2012 Got some data from a customer's R34 yesterday running a FNT .82 G3 vs Jeff's std .82 PU high flow on 18psi. There is about 250rpms differences in response with lot better road drivability. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6183252 Share on other sites More sharing options...
Harey Posted January 11, 2012 Share Posted January 11, 2012 Yup can see the improvement there. Also the hit of boost is slightly smoother so would give the tyres a bit more chance of holding on with the FNT. Interesting to see that he could only make similar ~280rwkw as well whereas on your car and others it has made 300rwkw+. Wonder what is/was holding them back. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6183295 Share on other sites More sharing options...
Crans Posted January 11, 2012 Share Posted January 11, 2012 Defiantly going to send my turbo back for the FNT upgrade, just gotta wait till I can afford a 44mm wastegate, may as well upgrade to external if im getting a new exhaust housing. Where can i buy a good quality gate for less than the $600 i keep seeing the turbo smart items for sale for? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6183314 Share on other sites More sharing options...
Hanaldo Posted January 11, 2012 Share Posted January 11, 2012 Defiantly going to send my turbo back for the FNT upgrade, just gotta wait till I can afford a 44mm wastegate, may as well upgrade to external if im getting a new exhaust housing. Where can i buy a good quality gate for less than the $600 i keep seeing the turbo smart items for sale for? I got my comp-gate 40 for $330. 44mm will be a bit more expensive though, are you sure you need it? Mine holds boost perfectly and I'm only running 18psi, if you run the full 20-23psi that the turbo is capable of then I'm sure the 40mm wastegate would be more than sufficient. Just keep an eye on eBay if you know how to spot fakes, there's plenty of genuine items on there Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/178/#findComment-6183325 Share on other sites More sharing options...
