Interesting to see that he could only make similar ~280rwkw as well whereas on your car and others it has made 300rwkw+. Wonder what is/was holding them back.
Note he was only running 18psi, I made 289rwkw@18psi on my hub dyno run, so quite similar. I believe Stao on his 320rwkw run was boosting to 23psi? In any case, I'd say you will need to run at least 20psi to crack the 300 mark on pump 98.
Edited by Hanaldo
Yup can see the improvement there. Also the hit of boost is slightly smoother so would give the tyres a bit more chance of holding on with the FNT.
E85 & more boost, gogo
Nope, Stao made 305rwkw with the exact same turbo I had and was only running 18psi also.
See how my boost is dropping to 15.5psi. No matter what I did to raise the boost it would drop back to 15.5psi. So no point in increasing it for it then to drop off up top.
More midrange punch
There is an adjustment on the back of the turbo, you can adjust the creep amount with an allen key. Stao can give you advice to doing this.
I think the outcome is that you will boost higher up top than down low, but thats not really an issue if you just turn the boost down to suit
Oh are you talking about the PU high flow? I was referring to the G3.
Got a graph of Stao's run? I can only find the one where he made 295@18psi with that turbo.
More midrange punch
Yeah true I just dont like the feeling of torque dropping off.
Hmmm havent heard of that?? Any more details? We tried all the studs to reduce the size of the wastegate path to hopefully increase boost up top but couldnt do it. I think my intercooler could have been restrictive.
Yeah talking about the PU high flow. Sorry your right Stao made 295rwkw on 18psi and 305rwkw on ~21psi.
there are two alen keys next to the flapper, did you try those?
it could be that you are getting so much volume through the mid range that you cap it out early and cant do anything about it.
either way your results are already good lol
It wouldn't be dropping off any more than it is now, I guess the slope would be steeper, but you'd still have more power/torque under the curve.
The torque curve was pretty wide on mine and abes. It Might have some thing to do with his return flow cooler. Thats the one went burning hot after 1 run and took 3 mints to cool.
Is that correct? Hareys cooler got hot after just 1 run?
If so you should definitely change that mate, that would be holding you back a long way.
You talking about my old intercooler Stao? Didnt know it was that bad? Anyway I changed to an ARC return flow when I changed to the SS1 turbo. So unfortunately cant directly see the difference, except Trent said after 15+ dyno runs the temps were excellent.
Not Jeffs. The other car with the G3 has a made in china return flow that went burning hot after 1 run and took agers to cool. Buy the cross over ones like mine with a decent 600x300x75mm core. That gives the best performance.
Tao, I wanna come past tomorrow and talk to you about high flows / get you started on one for me, as I'm biting the bullet on getting one. When is a good time?
Highflow? Get a SS1.5 PU. Be a man. Do da right fing.
After talking to Tao and testing his car, we've arrived at an SS1PU highflow as my choice. Stock looking compressor housing with modest power and hopefully only a little laggier than the standard turbo. Was very impressed with the Taomobile's power, the thing just wants to eat gutters above 4500rpm in any gear, but it's a bit laggy for my liking and daily driving. Can't remember what turbo he had fitted, but I'd rather more useful power and hopefully the SS1PU fits that bill. Will post results when I get installed and tuned :thumbsup:
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
