Good intake pipes aye. The 3 inch metal pipe fits snug inside it so not restricting it.
I Can supply if u like
There was no issue's with holding boost. Just how i set it up with the boost controll. Car feels like more than 200kw on the road.
It does feel really fast. And to think I got so much advice before I highflowed to get a bigger turbo, but I love the response of this unit.
Nice and torquey too
Fun!
Where did you get this intake pipe? I need a few my self.
In this case not sure if by using high pressure actuator holding more boost uptop would gain abit more kws, but that would be about the limit from high flowing a R32 GTT turbo.
I have a GCG highflowed R32 rb20det turbo that makes about ~235kw on 18psi dropping to 15psi by redline on an rb25det. Can hold 18-20psi to redline just haven't had a chance to get it tuned with that to see what it can make. I am 100% sure it is an rb20det turbo so you could probably squeeze a slightly bigger rear wheel in there if they managed to.
It has the valve on the compressor housing?
The Rb20det's high flow profile is smaller then what we normally do on RB25det. it can be made bigger, how ever the drivability would turn bad as its missing 0.5L and no VCT enhancing down low.
Rb25det would make power lot easier, Rb20dets are generally 20% behind in power.
I'm quite happy with how do the RB20 high flow :)
Tis a neat looking pipe. Can I assume correctly that this should fit an RB25 all the same? If so, what would you sell one for?
Isnt that intake pipe just a bit of straight 3" pipe with 2x45 degree silicone bends cut to the right lengths?
I would be a little bit worried about the silicone bends bending under cornering and acceleration load. Mine just uses a 90 degree metal bend but with fittings welded on so that the bov and pcv lines can be attached.
does that look like a metal intake pipe to you? :glare:
any competent exhaust shop can make up an intake pipe for you.
should cost anywhere from $100-$150~
yes it does..when you know how to look further.......cut that silicon sucker in half, get a short length 3" metal pipe and put those 2 'joiners' on both ends.. easy isnt it?? Thats how you create a backyard metal intake pipe that should work - refer cherring's car a page earlier on this thread.
Edited by rondofj
I was set out to make my own and after figuring it out its not too hard. To use all your stock oil breather and BOV return, just get a 3" metal intake pipe with 90degree bend, stick it in the front of the turbo and cut the breather and return where they touch the pipe. The pieces you cut off form the nipples to attach your shit back onto. Any workshop will charge little to nothing to weld these on(if you know someone with the welder).
Don't bother trying to make any fancy bends to fit shit. Trust me a 3" 90degree pipe fits the z32 and apexi filter snuggly.
if you're gonna spend $60 on this + 3" pipe to cut and fit in, why not just do that with the stock intake pipe, its been done many times before on here, theres even a DIY thread about it.
I did read somewhere that even with the $10 intake mod (stock pipe cut in half with metal pipe stuck in the middle), those rubber bends STILL suck close and dont work for everyone...
Both are pointless and shit ideas. I tried the half metal half stock(the bigger end). According to Tao, this is a loss of 65rwkw from back to back tests he done. I made 244rwkw. Add 60rwkw you get 304rwkw from the SS2. Ive got it sorted now, full 3" metal just need a retune.
Good idea - I was also thinking of using a 3" 90 deg bend from supercheap for $27 something and get an exhaust place to weld on those annoying breather nipples..just worried about the fit..
Ooops -thats actually a 45 deg piece, they do have them 90deg pieces in aluminium
Edited by rondofj
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
