Both are pointless and shit ideas. I tried the half metal half stock(the bigger end). According to Tao, this is a loss of 65rwkw from back to back tests he done. I made 244rwkw. Add 60rwkw you get 304rwkw from the SS2. Ive got it sorted now, full 3" metal just need a retune.
would be interesting to see if the intake pipe really restricts that much power alone from a intake pipe change. awaits your results with anticipation.
if i had time and could weld, i'd make a bunch of these metal intake pipes for you rb20/25 brothers out there.
If it sucks shut it restricts it massively, if it doesn't suck shut then it is fine.
any exhaust/performance car shop will make you one and install it for $200 max anyway so I don't know why people bother assing around trying to make their own etc.
Hanaldo just paid $400 for his intake pipe..lolz. Or was it 300?
With fittings for the bov and pcv connections from the stock piping? I highly doubt it.
Would love to see someone make them with the two connections (pcv and bov) and have it hook up to the factory airbox. I would buy that.
Ron picked it on this one. Get the silicone intake off ebay. Then add metal. This stops the silicone sucking in. The silicone internal is bigger then the o d of the 3inch pipe. Fits stock airbox and has bov return etc
I doubt u will make 60rwkw+ from a less restrictive intake pipe, thats more power than a granny corolla puts out at the wheels, anyways we will await your after-tune results..
Dude they already done back to back tests. check:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__860
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__1120
Check index.
The silicone ones I have seen the fittings are way off the standard locations, plus the turbo end is only 2.5". I fitted it in my R34 and the pod filter would not fit in the engine bay with the afm and pod bolted to it lol. I bought it from 888Autobahn or something from ebay. He gave me a refund but didnt really give me a reason.
i did the rev210 mod on my GTT, the metal pipe collapsed. Ok for standard, not ok in a high-flow, higher temp situation.
Chasers made me up a full metal intake from airbox to turbo.
Haha don't tempt me if only I had time. I cant see your intake causing a restriction at all. Plus the straighter the pipe better dose/flutter sounds
If your pipe is sucking closed you will make that much extra power, if it isn't then it won't really help much.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
