Bit of a novus question, but could the stock bov contribute to boost bleeding at higher rpm on the ss1pu's or are they usually good for 300kw+ ?
Yes it's possible, Stao believes the standard BOV bleeds off boost, though from memory boost tapered off with his setup too.
The BOV does have a 4mm hole bleeding air, for a smooth throttle roll off. You can tap an m5 thread in the hole and loctite a grub screw there to try it I guess.
near identical to my old setup - OP6 rear housing highflow, return flow cooler, stock airbox, 256rwkw on 98, 17-18 psi i think ,that tapered off a couple psi
Birds i think you'll need to look at something more than just the spring in your intake pipe. I did the rev210 mod with my intake pipe and one day i found it crumpled and collapsed. My guess was all the extra heat from having a hotter running HF turbo killed it, but i'm not sure. Chasers made me a full metal intake pipe and if i was doing it again, that's the only way i would go. Sure everything was fine to start, but it didn't turn out great in the end.
Just get Scotty to knock you one up, done quite a few HG intakes by this stage i reckon :)
Cmon, you should know the answer to this John..
The problem with running stock housings is they superheat the air, the more air you try to shove though them the hotter it gets the hotter it gets the less power it makes..
You could pump more into it but it wouldnt be safe and wouldnt give a realistic figure of how much power it is actually making..hence the need for e85 to help keep it cool...Which should work well...ish..
Either way its a pretty good figure though for what it is and the boost it is running,
I bet it feels pretty damn nice to drive as is too, but I think if you keep on the gas to long it will heat up quickly and then it becomes inefficient..
I know mine used to...If hes only gunna do quick sprints here n there it shouldnt matter too much though
I was wondering about a single run for comparisons sake.
Making an assumption (it's going to get hot, blah) is all well and good, in the real-world is the test.
Well as I said earlier, if it comes to that I'll get something made up, but there's no point yet if the spring is doing it's job for now. Come the time (i.e. E-flex tune with more poundage), I will most likely get Scotty onto it :)
Was your old turbo an HG?
Its more than an assumption mate..but don't worry I am 100% certain he can give me a run for my money if that's what your getting at ;)
lol how about you sort out your clutch and I sort out my tyres first...I lose traction in 3rd which is, somewhat disheartening. I'm a bit worried now actually, without 20psi my midrange may not be strong enough to pull ahead of you early on. Guess we'll find out!
Curiously guys, regarding the extra power/torque that the R34 RB25DET NEO produces in factory form over the RB25DET found in the R33 (I can't remember what the upgrade was - VVT?)...does this power difference net any advantage when it comes to this stage of modifying? I.e. should we expect the NEO engine to (hypothetically) make more power with the same modificatons (turbo, injectors, ECU, tuner, dyno etc.) as a non-NEO RB25DET?
Pfft..excuses already, how,about we just race.
wheel size rims & tyres do you run birds?
i think u need to upgrade to 18x12" wide with 325/30/18 rears :thumbsup:
265/35/18 on the rear...granted I do have them at 40psi, so there's probably traction to be had in lowering the pressures a bit. They are only KU31 so nothing special in the grip department. Thinking of swapping them for Nitto NT05s, as Ric (HEKT1K) is running them in 235/40/18 form @ 280rwkw with no loss of traction in 2nd. If I could fit 325s I would lol.
No excuses, just altering my predictions of the outcome. But there's no point running up against you if I can't even put 1 bar on the dial and maintain forward movement :dry:
I also want to see what your car is capable of without a slipping clutch, so get your shit sorted!
lol, my car puts down 1 bar just fine mate..
Good for you, mine doesn't! Read my post again :)
Can I get in on this race :)
If you wanna drive down from Canberra...we can make it a three way :3some:
Wow, I finally found use for that emoticon?
All 25's have VCT. The main differences between the Neo and the standard 25's had nothing to do with power. The differences that do affect power really make no difference at all once you get to this stage.
Where are you guys located
Whyyounotcomehere
Melbourne. 2 vs 1...you come here.
:/. I know you edited that
I edited my post, but not the part about me struggling to put 1 bar to the ground!
Good to hear your result Birds. I still need to post my updated dyno result.
Its funny how before there weren't results for the ss1pu, I posted mine and everyone is acting like there is something majorly wrong with the car when it initially made 242kw..
Meanwhile now we have:
Birds 252kw
Kasko 250kw
Myself 251kw
And that now appears to be accepted as normal. Gotta love forum e-mechanics :)
On another note, I took my car to Wakefield park on Sunday...I think I may have had a bad batch of fuel since it was pinging on the freeway during the drive down however I put in a new batch of fuel then 'tested'' it after which it didnt ping at all so decided to take it to the track. Only did 4 sessions and was taking it easy since I didnt want to risk the car but the turbo is pretty nice on the track. Good power to use out of corners, more top end would be nice but whereas the car felt super underpowered on the track with the stock turbo, it now feels... i wouldnt say fast, but normal.
The turbo is torquey enough to lay long black lines out of corners in 3rd gear if you wish, nice to see them getting longer and longer in the rear view :)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
