Problem is my housing is made the way it is with the gate attached..would be alot of effort to change it, making a new housing and all..I can do a billet wheel no worries though..
Try an "F1 racing" clutch, which also goes by the name "gripforce". I have one in my car and i know of several in cars pushing 300+rwkw and going for 2 years+. Not bad for a $250 clutch :thumbsup:
I managed to organise a clutch from a bloke in Sydney KB clutch engineering.
He came recommended by a few of the ACT peeps once of which is running one in their GTR which is still holding up with 5k launches.
The guy sent me the following quote via SMS so I dont know what it all is but this is how it came:
HD cover assy
HD clutch plate organic facing SBF
Release bearing
Freight to canberra
$410
Nothing wrong with organic for the street....though not sure about 5k launches.
I have a JB in the R33 and an NPC in the fat slug (so much better than the 2nd cushioned button that it replaced).
I had a extra x2 heavy duty organic and died pretty quickly with my old 33 and 250rwkw just slipped while driving in 3rd one day
If I did it again I would get a extra x3 heavy duty cushion button it's really street friendly and u won't need to upgrade any time soon and wont have to waste 350-400 for labor to fit another clutch when the organic dies
Have you got the part number?
http://www.ebay.com.au/itm/NISSAN-SKYLINE-R31-R32-R33-RB25-DET-ENGINE-/220939836848?pt=AU_Car_Parts_Accessories&hash=item33710a5db0
which do you prefer??
Those were the only 2 clutches I considered, otherwise I was going twin plate..
I ended up with a freshly rebuilt NPC 10' and flywheel for half price of a new one...
but can anyone tell me if flywheel bolts are 12mm cause if they're not I have a problem :unsure:..??
Both are great streetable clutches. I would be happy with either.
The JB required modification to fit, something JB denies was necessary but was required. It came with a Valeo pressure plate from memory.
The NPC/Exedy has been faultless.
I think I would have no issues doing above, infact I know the SS1PU is slightly larger then the GT-RS all around and was pretty consistent when on the dyno. I'll be back with few more wastegate side updates and can do some comparisons with what Trent's got in his PC.
Also found most tuners would retard timing as "insurance" for stock motor when it do hit 20psi. That explains the missing mid range, an update to the wastegate assembly is made, so all new units would have no issues holding boost using EBC with a 14psi actuator. Also the updated module is available for all ATR43 series at a cheap cost.
For that Billet TD06 there is no way it can be modified into a stockie bolton the possition of the turbine outlet is way off to stock 6 bolt nissan pattern. So it will have to be the way it is. I'm planing to let trent do some tests on his New Ceffero.
Trent should have a couple of GTRS tunes on RB's. I know Dave has one on there with nismo 555cc and EBC. Easy to compare...
Its been a while seeing the Greedy copies around with few good working examples. So we've imported few. The first one I'm interested to try is the TD06SL2 in 10cm with T3 flange turbine housing running 20G Billet compressor wheel.
It has been pulled apart and rebalanced (tolerance is about twice higher then where I normally set them to, its now corrected). to make sure every thing can work accordingly.
Those turbos are externally gated only and available to every one for $850 including GST and 12 month local warranty. I will refer to it as the EXGBTD06SL2
Looking through the turbine design, it appears been able to make plenty of torque, but I'm not too sure about response. There is also room in FNT turbine upgrade. I might be able to adapt internal gate onto it with the Nissan 6 bolt flange.
Just noticed in the Kando thread about cracked td06 turbine wheel.
http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/page__view__findpost__p__6306795
Compare to what you've offering for sale above, Since above is also made from the same origin, is yours same or better? any idea on whats causing the problem?
The turbine wheel bends backwards or break vertically during a course of impact. The horizontal crack is from Heat, some thing to do with the material content of the alloy its made of. Generally running E85 and external gate plus not so much boost would keep the EGT low, that avoids issues like above.
How ever I have seen similar problem from a T70 Chinese turbo years back that was used on a Ford 4L +T. The car initially made 370rwkws on pump 98 for a while before the driver noticed lack of performance through time. The turbine wheel had lots of horizontal cracks with chucks missing, the edge of the wheel blade appeared rough like a wire brush. Luckily the it was a old T04 copy so I managed to rebuild it with a geninue Garrett wheel and it was all good.
Most turbo builders would contract specialized foundries to forge their parts to the specifications they require. The single incident is not good enough to conclude Kando or all other Greedy copies are bad, certainly there are many more working examples plus mine is yet to be trailed.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
