Guys,
How about starting another thread "For Clutches" as this is starting to hijack the Hypergear Turbo thread.....
Dont get me wrong (its all interesting as I will need one soon so i am whatching what is said) but its getting a little off topic for poor Stao & his fantastic turbo's....
Just a heads up ok dont want to put any nose's out of joint so to speak....
Dazza
If Stao has an issue with it I'm sure he'd say so. He indexes all the pages in this thread so it's not like it's difficult to find the sections relevant to your interests. I think this is a pretty important part of the turbo selection process as people should know what works with what. I like that the threads, both Kando and HG take a focus on helping people with their whole setups instead of just focusing in the turbos. We're like macro communities :)
Its good to have documentation from all range of supporting mods working with the turbo. I will index them in the main page.
I've been taken some time off working on my electric turbo again. lol here are some latest updates:
The new charger runs of 44V 120AMP of power from a 2x 6S power source with RPM controller.
I've installed it on to a Daihatsu Sirion with a 3cyc 0.97L engine. This car makes from 0 to 100KMs in 21secs factory. lol
After appling the charger in 3rd gear full throttle it actually made the Speedo rising a tinny bit faster. There is a just noticeably acceleration gain with the charger is activated and not. I'm installing it on the R33 for dyno runs next weekend. hopefully making better result then the previous one.
Plus I'm working on a VNT .82 rear housing for the G3s hopefully getting SS1PU's response with 330rwkws top end.
Can this new VNT housing be made for external gate? I just purchased a wastegate and highmount so as discussed a month or so ago my turbo will be comming back to you soon.
Will try and get it off this weekend
Trying to decide if i should send you guys my stock rb25 turbo or buy one off you or buy a GTX30/76, chasing 400-450hp, what would you sell me? i would like too stick too Australian products.
Edited by 51NNA
The limit for a Bolton G3 on a stock exhaust manifold would be 400rwhp with proper mods on pump 98, unless if you are going for E85 then you can get that 450rwhp+ (abe's R33 358rwkws).
Or you can high mount It run external gate, which would be the best solution for the goal, and reduces the cost in building the turbo to just $1000. We also have a externally gated turbo called the SS3. That would reach you goal with possibly the best response.
Pump 98 results and details from that turbo is in page 120
It was a billet wheeled turbo based in a SS2 externally gated housing. It was very responsive how ever only worked well externally gated, internal gated version was about 30kws short. Its a very different turbo to the G3, how ever you can run that rear housing with it and the results won't be far off.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
