Update some results from the ATR43G2.5 internally gated.
This little turbo has pretty much all the big features from the original G3, It is 30kws short, with 300RPMs better response. It makes just under 300rwkws @ 20psi on pump 98 and 350rwkws @ 20psi on E70.
All runs are done internally gated using a soft 14psi actuator and EBC. The Lever mod works perfect on a .82 rear housing.
We've also trailed the Electric turbocharger, and surprisingly it made 2.1psi of boost, made a difference of 20HP and 44Mn of torque.
Stao that E-turbo is only on your DET motor, it will probably work better on a REAL NA motor. You should ask a customer to test it. With that sort of flow it is possible that it wont need any tuning.
That G2.5 is also a nice looking unit. I would be happy with one of those :)
The G2.5 has stepped down compressor trim from 58 to 56 and stepped down compressor from .70 to .60. Still in a .82 rear housing. This turbo has pretty good down low torque with excellent top. Don't forget this turbo is still internally gated. run external would easily gain an extra 20kws.
Performance was consistently around 285rwkws at 18psi on pump 98, realistically there isn't much of a point engineering a bolton turbo that goes up to 330rwkws while 290rwkws is all stock exhaust manifold can pump out internally gated
(also did you know cyc No. 1 and 6 on the OEM manifold does not line up to the engine head? boggie Nissans trying to cut budget from recall, Abe managed better result port matched)
I run the Echarger on my little Sirion with 1L 3cyc engine and it blew cyc No. 2 as soon as it comes to full power in 3rd gear. 2.1PSI from a 6cyc 2.5L would be about 5psi on a 1L 3 cyc engine. I think they all needs to be dyno tuned and checked before hitting the road. The shaft speed is fully controllable with a speed controller.
How ever E85 is seriously fun. Based on a solid 98 performer, making power out of it is a walk in the park. I keen to see what the G3 can do on E85, might be reaching 380rwkws internally gated.
BAZINGA! You've pretty much just built me the turbo I was looking for :)
You've got me. What is one of these puppies worth inc postage to metro Melbourne?
My intention is this + WMI.
Also what sort of battery/charging system would one require for the e-charger?
The internally gated Rb25det bolton version $1330 inc GST and oil line, and external gated version is $1080 inc GST and oil line.
The current E turbo runs on 44V that makes around 40,000RPMs. I'm in the process of getting a higher KV ed motor and some larger comp wheels. I think the current prototype is plenty for a little 4 cyc engine.
Do it!!!
That graph looks the goods just on PULP, putting out close to 200rwkw at 4000rpm and the difference between e85 graph seems negligible down low.
WMI should put you up near the e85 power up top as well!
It looks like a good balance between response and top end with limited boost bleed problems.
Stao, is the boost graph the same for the 98 tune and e85 (full boost by 3900) because it seems you only posted the e85 graph?
Edited by Mitcho_7
The E85 and Pump 98 made no difference in response. was getting the exact same response on both fuel, or maybe Trent didn't have enough time to modify sittings down low as we've tuned 98 prior E85, it was about 1AM yesterday when we've finished. There is still abit of work left in the ECU.
On road its mental to drive. it would wheel spin hard (not a the little wheel spin that makes a sound) at 3rd gear (so's every other gears except 4th). Its pretty dangerous to drag off the lights as I can't get the car running straight. I've only full throttled it once in 4th full throttle, didn't span out but its the feeling that I would not take my eye off the road even for a blink.
Its pretty responsive for the power range for every day with very solid power band.
Haha sounds like a ripper of a turbo - with aggressive power delivery and good top end- this could be one of your best turbos Stao :)
So your gonna buy one?
Fixed my clutch (kinda see thread in drivetrain)
This SS1 feels insane with the new clutch
It has no hesitation to spin the wheels in 2nd and even 3rd. Dragged Someone at the lights as well stao and smoked them literally
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
