Have you done the SS1pu on e85 yet?
Would be really interested
Really not liking the idea of always having to run 20psi to get 250rwkw when these other turbos that people are strapping on are making simple 240 etc on lower boost such as 16-18psi
Pm me or post up here if you could
Cheers mate
Aside from where it's sold, can you think of any reason why not to as a tuner?
It makes their job too easy, no challenge, as it's not on the verge of knock all the time. :)
Seriously, the only reason not to run it is the extra fuel it requires, larger fuel system, less k's to the tank. The positives outweigh the woeful economy tenfold. Clean engine, more torque/power, lower temps, cheaper, environmentally friendly, not having to line the pockets of thieving oil companies...
Shhhhhh. :D
Haha copycutter availablity is the only issue. Oh and supposedly it melts fuel rails and ruptures fuel lines etc etc according to people that dont like ethanol for some stoopid reasons
Shhhhhh. :D
Hurry up Penrith E85 pumps!
I might be wrong but how is running e85 cheaper?
its $1.18 vs $1.50 at the moment. and say it burns 30% more $1.18 is equivalent to $1.53 in petrol cost. so not cheaper now but the power gains is a benefit for virtually the same cost. but when 98 goes up which it will, you will save.
O_o. Plus a new fuel system. So I guess it's much like gas. Some people will do it thinking oh this is a great idea and the rest will just continue on with their lives. Although I was told that the only way my hypergear will be reliable is with e85 as it heat soaks really bad. In that perspective I can see why stao is listing the e85 figures. Let's get some more dyno sheets in here already. Any more testing done yet?
E85 won't be +30% if you do mainly highway of say 80km/hr+ kms... my GT-T got to +10-15% on 98 fuel economy with E85 and that was back when E85 was 97cents a litre... was much winning :D
and to the person thinking of going z32 ecu nistune - i think change your ecu plans, FC or Link plugin. Nistune is great, and i highly recommend it... but for 33 owners, there are better options.
You know there's a United with E85 at the top Old Bathurst Rd in East Blaxland now? That's only 6 or 7km out of Penrith
Surely the 'Riff will get one soon.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
