The boost drops off a fair bit up top.
303kw on about 22psi droping back to 19/18psi is a decent result, but it doesnt seem that much different to the g2.5 in terms of response.
The g2.5 made close to that power running 98 on only 20psi didnt it? and pretty close to 200kw at 4000rpm as well
Edited by Mitcho_7
Yeah it's looking like the turbo I'll be after. Want to hit 300rwkw or near enough and hopefully shoot above with e85 if it's ever readily available where I live.
Was gonna use stock manifold but after looking what Stao has said and the Dyno graphs I think I will look at getting a 6boost or brea manifold, depending what is available to me
The temptation to go external gate is there, but I think I'll stand by internal gate
same turbo just pump 98 internally gated. Only shows bit more responsive on paper, but on road its very different to the G2.5. Further response gain will cost top end power unless going external gate.
How ever small differences do adds making a pretty big difference looking back to the old G3. So just have to keep on working at it.
Results from the newer SS2 prototype on Pump 98 internally gated in bolt form. It made final of 302rwkws and did actually manage 200rwkws by 4000RPMs. Pretty sweet to drive on road. At this stage that every HP its getting is based on a trade off of some response. Probably only a tinny bit more room to play with. I will trail one more wheel on it in about a week time.
Wow I'm excited. Glad I sent it back for updates.
What is the difference between this and the other wheel you will be testing next?
Different profiled wheel blades, also complete with a bigger turbine housing.
I've made one more billet wheel with minor alterations to the hub that I like to get some result off.
Just over-layed new Ss2 against old ex gate 307 result and original 315 int gate result on paper.
New one is impressive. New vs 307 are identical from 4500 to redline. 307 makes more around 3700 but dips at 4100 then they meet up.
Original 315 makes less from 33-5500 of up to 60hp then only makes a bit more to redline compared.
Excellent result
Stao,
Any hope in a twin scroll internally gated turbo making somewhere over 300rwkWs on 98 & full noise around 3500 to 3700 rpm?
Here's an example of what the EVO boys use:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-VEVO-039&Category_Code=NEW
The idea of running twin external gates etc.. too much money & space used up.
Just put hi-lighter over it. Forgive how rough it is etc.
Yellow is original 315 result
Blue is 307 ex gate
Green is new one with .82 rear
Maybe Stao can get proper comparison sheet when he try's next wheel
Edited by t_revz
Stao,
http://www.atpturbo....tegory_Code=NEW
If that turbo was on decent boost before 5500rpm I would be supprised
Edited by SimonR32
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
