Just put hi-lighter over it. Forgive how rough it is etc.
Yellow is original 315 result
Blue is 307 ex gate
Green is new one with .82 rear
Maybe Stao can get proper comparison sheet when he try's next wheel
Thats with all of them running about 22psi yeh?
I think the new setup internally gated has the nicest curve
Didn't check boost actually But they are all final results so yeah around that. Too hard searching around on my phone to do it properly
But new one runs 82 housing not 63 so should be cooler on track. yet response is still on par.
Further updates. This is the 2nd SS2 prototype been trailed. More responsive and made more power to previous version. Internally gated.
Max of 312rwkws on BP 98 and 210rwkws by 4000RPMs
22psi by 3750RPMs, 20psi by 3650 RPMs:
U
Max of 348rwkws on E85, probably another 15kws in it as my fuel pump is out.
I believe this turbo would make a pretty responsive 250~280rwkws internally gated on a stock manifold on pump with around 18psi of boost. Would go crazy to run on external gate and e85.
The 5 bolt externally gated version is cheaper then the bolton internally gated version. That is $1100 The factory bolton version is $1375 and oil line is additional $88 which is required to complete the setup.
For any one whom's looking for the externally gated setup, I can supply brae auto's high mount manifold with any turbochargers, with $200 discount off total.
pretty good value..
Too late now. You already picked your side
Its never too late ;)
If I ever get done for my external gate prompting a rebuild, I would definately consider it, until then my car is fast and I am happy... :happy:
For any one whom's looking for the externally gated setup, I can supply brea auto's high mount manifold for $900 with any turbochargers, they are $1100 retail, so $200 off the total package.
50mm external gate is for $200.
Fark cheaper then the SS1PU
I thought external gates were ok as long as they are plumbed into the exhaust?
Or are you running a screamer pipe?
the breas are a side mount manifold yes, or do they do a top mount aswell?
Can you weld up something to run the external wastegate off the underside of the rear housing (and plum back into the exhaust futher down) rather than having to buy a new manifold or does that not really work that well?
It can be done, gain is more significant if the external gate is fitted on to the exhaust manifold.
Stao, in your eyes, what would work best if you had 2 options with the ss2, a internal gate ss2 on a brea manifold..or a external
gate ss2 with ext gate put on stock manifold?
cheers
darren
Obviously Externally gated setup would pickup more power. There should be 20kws gain running external gate on my current setup.
well I wasn't sure it was so obvious, you said you picked up 15rwkw going from Brea from standard mani ..so i would have thought
the gains from standard manifold to ext gate might have only closed that sort of figure in..guess its one of those things you(not you, but someone)
really have to back to back...
cheers
darren
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
