Just put hi-lighter over it. Forgive how rough it is etc.
Yellow is original 315 result
Blue is 307 ex gate
Green is new one with .82 rear
Maybe Stao can get proper comparison sheet when he try's next wheel
Thats with all of them running about 22psi yeh?
I think the new setup internally gated has the nicest curve
Didn't check boost actually But they are all final results so yeah around that. Too hard searching around on my phone to do it properly
But new one runs 82 housing not 63 so should be cooler on track. yet response is still on par.
Further updates. This is the 2nd SS2 prototype been trailed. More responsive and made more power to previous version. Internally gated.
Max of 312rwkws on BP 98 and 210rwkws by 4000RPMs
22psi by 3750RPMs, 20psi by 3650 RPMs:
U
Max of 348rwkws on E85, probably another 15kws in it as my fuel pump is out.
I believe this turbo would make a pretty responsive 250~280rwkws internally gated on a stock manifold on pump with around 18psi of boost. Would go crazy to run on external gate and e85.
The 5 bolt externally gated version is cheaper then the bolton internally gated version. That is $1100 The factory bolton version is $1375 and oil line is additional $88 which is required to complete the setup.
For any one whom's looking for the externally gated setup, I can supply brae auto's high mount manifold with any turbochargers, with $200 discount off total.
pretty good value..
Too late now. You already picked your side
Its never too late ;)
If I ever get done for my external gate prompting a rebuild, I would definately consider it, until then my car is fast and I am happy... :happy:
For any one whom's looking for the externally gated setup, I can supply brea auto's high mount manifold for $900 with any turbochargers, they are $1100 retail, so $200 off the total package.
50mm external gate is for $200.
Fark cheaper then the SS1PU
I thought external gates were ok as long as they are plumbed into the exhaust?
Or are you running a screamer pipe?
the breas are a side mount manifold yes, or do they do a top mount aswell?
Can you weld up something to run the external wastegate off the underside of the rear housing (and plum back into the exhaust futher down) rather than having to buy a new manifold or does that not really work that well?
It can be done, gain is more significant if the external gate is fitted on to the exhaust manifold.
Stao, in your eyes, what would work best if you had 2 options with the ss2, a internal gate ss2 on a brea manifold..or a external
gate ss2 with ext gate put on stock manifold?
cheers
darren
Obviously Externally gated setup would pickup more power. There should be 20kws gain running external gate on my current setup.
well I wasn't sure it was so obvious, you said you picked up 15rwkw going from Brea from standard mani ..so i would have thought
the gains from standard manifold to ext gate might have only closed that sort of figure in..guess its one of those things you(not you, but someone)
really have to back to back...
cheers
darren
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
