Mitcho_7 Posted July 2, 2012 Share Posted July 2, 2012 That does seem dodgy. How much is eflex/united e85 at the moment? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426180 Share on other sites More sharing options...
battery Posted July 2, 2012 Share Posted July 2, 2012 E70 was like $1.02 when I filled last Thursday. At that time im pretty sure 91 was around $1.20 and 98 $1.35?? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426190 Share on other sites More sharing options...
GTScotT Posted July 2, 2012 Share Posted July 2, 2012 E85 always makes me think aim higher lol. If only it helped response as much as it helps power, that would be the ants pants. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426224 Share on other sites More sharing options...
scotty nm35 Posted July 2, 2012 Share Posted July 2, 2012 You got da high comp bro and you worried about response? I don't see any other option for you... You can deny it as much as you want but I can see you filling at caltex within the year. lol. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426340 Share on other sites More sharing options...
ARTZ Posted July 2, 2012 Share Posted July 2, 2012 lol...can also see him saying "how good is this" when he does Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426410 Share on other sites More sharing options...
GTScotT Posted July 2, 2012 Share Posted July 2, 2012 lol when caltex roll it out across the state ill be using it for sure. at the moment theres nothing local to me which supplies it. if the car ran out of fuel its like hey lets go for a half hour drive with a jerry can lol about half an hour in only 2 directions. much further in any other the high comp is due to retire soon. DET block has been bored 20thou and CP pistons at 8.5:1 have been match bored already. crank is next (once i pay for some dental), will match some bearings to it and check the rods. put it back together shortly after and grabing a 20g to go. plan is to pick up some detchwerks 1000ccs while im at it so im ready for the good stuff when its actually available keep in mind my car is intended as a frequent driver and track car. the only ameture friendly track is over 2 hours drive away and i havent seen a caltex there let alone any eflex supply lol. but sooner or later ill join you guys on that bandwagon, yes. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426588 Share on other sites More sharing options...
Birds Posted July 2, 2012 Share Posted July 2, 2012 This is very true but 2nd gear is snapping into 3rd is my fav! It steps out out when ever you plant it in 2nd. Have you fixed your clutch slip? My tyres hold strong in 2nd, it's the clutch that let's go when the power comes on! Meant to have clutch in the other day...but we had a customer warranty job to fix, so my car should be on the hoist tomorrow hopefully! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6426814 Share on other sites More sharing options...
ssxRicho Posted July 3, 2012 Share Posted July 3, 2012 Filled up with UE85 @ 97c on Friday Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6427783 Share on other sites More sharing options...
kosmo90 Posted July 3, 2012 Share Posted July 3, 2012 S1 R33 3 inch dump,high flow cat, 3 inch exhaust Apexi metal intake pipe with pod --- problem? China fmic --- problem? 044 fuel pump 660cc high flow injectors Superspark coils with copper plugs @.8 Nistune ecu Eboost street SS1pu 277.0hp @17psi There isn't any boost leaks, we checked while there. I also double clamped all the pipes to make doubly sure. I did check at the time whether i pulled all the rags out as well. It's got me stumped, any ideas?? Encouraging news. Replaced the cat with a 100cell 5inch body metal cat (forget the brand,venom?) Plazmaman FMIC with a turbosmart fully recirc BOV 3 inch metal intake (thanks to Scotty) I put a nistune map on that Stao gave me and it's boost waaaaay earlier, only put the map on for a trial. It coughs its guts up any higher than 3000rpm but i did see 10psi at quarter to half throttle by then. I've put the Hyperdrive map back on until i get it to the dyno again. Next problem is, do i take it back to Hyperdrive or Pzp? or even post it off to Toshi? Wish i could take it over East, sounds like theres some great tuners over there. Anyone know of anyone else in Perth that tunes r33 with z32 ecu? Cheers Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6427922 Share on other sites More sharing options...
scotty nm35 Posted July 3, 2012 Share Posted July 3, 2012 Great result Joe, glad to help. Trent should get into live internet tuning. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428040 Share on other sites More sharing options...
Manuel Kasko Posted July 3, 2012 Share Posted July 3, 2012 Trent should get into live internet tuning. +1 like what guilt toy was doing at one stage. If no one taps into the Perth network I am going to have to Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428047 Share on other sites More sharing options...
kosmo90 Posted July 3, 2012 Share Posted July 3, 2012 Thanks Scotty, it was great to hear the turbo spool earlier even if i couldn't use it. So how about it Trent? I'll be your first Guinea pig Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428082 Share on other sites More sharing options...
hypergear Posted July 3, 2012 Author Share Posted July 3, 2012 Encouraging news. Replaced the cat with a 100cell 5inch body metal cat (forget the brand,venom?) Plazmaman FMIC with a turbosmart fully recirc BOV 3 inch metal intake (thanks to Scotty) I put a nistune map on that Stao gave me and it's boost waaaaay earlier, only put the map on for a trial. It coughs its guts up any higher than 3000rpm but i did see 10psi at quarter to half throttle by then. I've put the Hyperdrive map back on until i get it to the dyno again. Next problem is, do i take it back to Hyperdrive or Pzp? or even post it off to Toshi? Wish i could take it over East, sounds like theres some great tuners over there. Anyone know of anyone else in Perth that tunes r33 with z32 ecu? Cheers Preferably Allstar in WA, Just get them do a check up and some patch up if required. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428084 Share on other sites More sharing options...
kosmo90 Posted July 3, 2012 Share Posted July 3, 2012 I'm sure i've tried them before and they wouldn't do r33 with nistune, i'll try again tommorow. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428091 Share on other sites More sharing options...
t_revz Posted July 3, 2012 Share Posted July 3, 2012 I'm sure i've tried them before and they wouldn't do r33 with nistune, i'll try again tommorow. Pretty sure Hanaldo has said that before also! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428118 Share on other sites More sharing options...
ARTZ Posted July 3, 2012 Share Posted July 3, 2012 nice.. Filled up with UE85 @ 97c on Friday bargain, must fill up tomorrow....so you lovin it yet, any better times at PI?? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428237 Share on other sites More sharing options...
Birds Posted July 4, 2012 Share Posted July 4, 2012 So this is what happens after 400-500 launches, several DECA/skidpan days and 3 years of daily driving. It is was a cushion button, so there's supposed to be organic lining between them fancy paddles...which have about half a mm left in them. Note also the heat spots on the cover plate. All in all a solid effort from the Exedy, as she was still letting me launch hard until the very end, only giving out under too much boost (SS1PU POWAAA) and I think that was clamping pressure related. Would definitely use this clutch again if I wasn't making too much power for it. Waiting for my flywheel (read: saucepan) to come back from being machined and then the NPC organic + reco gearbox go in. <2 hours work so far, not bad for a gearbox and clutch change. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428775 Share on other sites More sharing options...
Rolls Posted July 4, 2012 Share Posted July 4, 2012 (edited) So this is what happens after 400-500 launches, several DECA/skidpan days and 3 years of daily driving. It is was a cushion button, so there's supposed to be organic lining between them fancy paddles...which have about half a mm left in them. Note also the heat spots on the cover plate. All in all a solid effort from the Exedy, as she was still letting me launch hard until the very end, only giving out under too much boost (SS1PU POWAAA) and I think that was clamping pressure related. Would definitely use this clutch again if I wasn't making too much power for it. Waiting for my flywheel (read: saucepan) to come back from being machined and then the NPC organic + reco gearbox go in. <2 hours work so far, not bad for a gearbox and clutch change. I raise you my button clutch, I did this just daily driving the thing ; ) Totally destroyed it, you can see the heat discolouration and warping of the rivets, with only 150rwkw as well lol. Edited July 4, 2012 by Rolls Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428787 Share on other sites More sharing options...
Birds Posted July 4, 2012 Share Posted July 4, 2012 You know, you're not supposed to be proud of destroying it that easily Was yours cushion button or button? Looks to have the buttons of a cushion, but your sprung centre is different to mine? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428812 Share on other sites More sharing options...
Rolls Posted July 4, 2012 Share Posted July 4, 2012 You know, you're not supposed to be proud of destroying it that easily Was yours cushion button or button? Looks to have the buttons of a cushion, but your sprung centre is different to mine? cushion apparently, but it was TERRIBLE to drive, shuddered and f**ked my gearbox, in the end it still had massive bite and shudder but would slip on hard changes to 2nd. I am renowned for having no mechanical sympathy haha. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/280/#findComment-6428889 Share on other sites More sharing options...
