derrrr a few pages back lol nvm... I notice the internal gate is still there??
I really liked the way how the KKRs560 had the center divider grinded out for the internal gate to work. But either way that is not a "real" twin pulse housing. The pulse in the center must have the exact clearance to the turbine wheel as the rest of the turbine housing profile does (20 thou), with the pulse separated from the manifold all times. Realistically it needs two external gates and gets treated as "twin" turbos.
I seen one ( I think it was a Toyota turbo) which got 2x wastegaes in the turbine housing as in one per pulse. It will has to be setup that way for the to work. To get that working the pulse will need to be twisted so it actually faces the dump pipe area, Will need a new casting and etc to get that working. But nothing is impossible.
FINALLY got my car back on the road after about 4 months of no rego due to defect lololol
So good to feel the pull of a G3 again, right now I can't even fathom how it would feel with an updated version or even SS2....
Trade that old dinosaur in for some new technology!
Can't afford the upgrade and retune to be honest...since my 33 got defected for missing front numberplate (lol my fault...) it cost me roughly $2700 to get a roadworthy for it again (not to mention buying another car since it was my daily). I've spent enough on it for now, I'll just wait until I get used to and subsequently bored of this power again, then I'll see where I'm at.
Is that what it costs to clear a defect? man everything here in nsw is a total rip-off lol
lol what do you mean? My defect clearance included engineer's certificate for ALL modifications (~$1500) and fabrication+fitting of child restraint anchoranges (~$850)
That's the biggest load. Sif I'm ever going to be putting kids in my car. Even if I did, I'd take the trouble of getting the anchorages put in then. Why is a vehicle unroadworthy just because it can't carry kids seats? :/
Edited by Hanaldo
So that hole is ok to use? Have thought putting thd baby seat in the car might get some sympathy if I ever get pulled over.
Or they might think I'm being a bad parent putting a kid in a skyline :laugh:
I fail to understand how these cars got complied without getting anchor points fitted. My R32 has 3 of them, and there was no way it was going to pass the import/compliance/rego inspection at Regency without them. That was last century!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
