Also kasko, that result you were comparing your car to could be on a hub dyno and i think birds' result could have been a hub dyno as well, so keep that in mind.
The only true comparison would be to get the all on the same dyno. I wouldn't be worried too much about it to be honest
Edited by Mitcho_7
Bird's result was from an roller dyno and so's Peters. could be the tuner is conservative, different dyno, differences in the exhaust, cooler, or what ever it might be. Since my car's off the road I'll organize photos post up some progresses of the Turbocharged Kia sportage with high roll over risk project that we are half way through for bit of laughter.
just a quick question are do you guys use bellmouth or split front pipes?
This is my justification, if split dumps produced more power and better boost response, why would manufacturers produce bell mouth dumps?
Bellmouth = bigger = more flow.
Pretty simple. Sick of all this merging the gasses bullshit, either go bellmouth or man up and go the external gate. :)
Or both!? :woot:
Most splits are shit and cause more problems than they solve with wastegates jamming etc. Even if you get one to work properly it's purely a wank factor thing; imitation screamer pipe that sounds like ass. Bellmouth = don't look back.
My 258rwkw was on a roller dyno at Race Pace who certainly aren't known for having a happy dyno.
Peter's full boost at 3250 got me confused though...mine happens at around 3600-3700. I have a more restrictive setup with my catted exhaust and lack of a 3 inch metal intake, but I wouldn't think the response difference would be that great...unless you have an updated SS1PU? :S
Not all split dumps are vent to atmo.
cheers guys, ive had my car for about 8 months now and have done suspension etc so just starting to look at adding power, amperformance here in sa do very impressive looking split front pipes and was looking at getting one but he makes them in such a way that i dont think they would work with the hiflow which lead me to wonder if anyone was running one. will look into it more but atleast you guys have given me insight into which front pipe i should be looking at. :)
intake pipe makes abit of differences to response. here's one more result from a customer's R34 skyline running SS1PU. made 255rwkws @ 16psi with 2psi creep mid range. This car's also runs a return flow cooler that get abit hot. With a proper cooler at 20psi it should be getting pretty close result as my test car.
There has been a recent FNT angle update, might affect tinny bit in response but not power wise.
When will the FNT update be available Stao? I've been waiting for your next development to order a turbo so this might be good enough to make my wallet a bit lighter :)
Here's the interesting part...despite my full boost not coming on until a bit later...my power band is basically the same as Peter's and the above customer's...I make the same power at the same RPM points?
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
