lol ramps a little steep, 150-330kw in 700rpm
He explained why that is. It's a 9 second ramp as he is concerned about the stock internals holding up to such huge power.
It would make for an interesting drive, however :)
Wouldn't a shorter ramp actually make it look laggier on paper since the dunno allows the rpm to climb faster?
yes Trent wasn't very confident with stock con-rods when we got to around 375rwkws, faster ramp puts less load on to the engine, and generally result that sort of power curve. I was hopping for 400rwkws at the time ;) .
On road its obviously not as responsive as the SS1PU or the SS2, but pulls crazy after 4G on full throttle. I'm putting the SS2 back on for the final tune based on external gated setup and e85.
My ss2 is booked in at allstar garage in 3 weeks. Running it in between now and then once brake pads arrive. Hopefully have a drive this weekend
The turbine housing used on that run is a .82 type B rear. I believe type A would have produced more power. How ever this is the first prototype that made into this sort of power range, so there are many areas that could be twicked for even better result.
I think G3 will max out around the 370rwkws mark based on the same setup. I will do a test based on it in the next few weeks. I've also got few idea on high flowing factory R33 and R34 turbos that I like to trail.
Further evaluation on the SS2. it made 337rwkws on e85 externally gated at 18psi peek just touching 20psi. I've also trailed it based on internal gate running boost controller and straight off the actuator.
The solid red and green are from internal gate, Green is internal wastegate pressure:
Boost curve for all runs.
My ss2 internal gate turbo is ready to be picked up tomorrow.
Going to installed on a healthy rb25neo, ID 1000 injectors, z32afm, Hybrid turnflow intercooler with one of Scotty's metal intakes.
Will be tuned by Trent at Chequered tunning.
Will post up results when everything installed. Probably sometime in the next month
Ooo, nice one Tony. e85 I hope?
Nah not e85. It's my daily and I do alot of road trips on weekends.
So don't like the idea carrying jerry cans in the boot everytime I need to travel.
But yeah ID 1000 injectors just in case I ever change my mind in the future :P
It would be interesting to see what your G3 style hi-flow(PU?) did on a stock exhaust manifold and E85,
eg ..most power for a full stocky look
cheers
darren
hypergear can machine the stock rb t3 inlet cover to match up and bolt onto the ss series of turbos which means stock looking turbo
Edited by Dan_J
Yes can run stock comp housings on those.
Some updates with factory exhaust manifold fabrications. Well yes it is a not an welly engineered part. The port don't match up with the head as we already known, they had huge lumps in side the collectors, looks like they were trying to seal the bolt holes when the bolts aren't fastened. The lump took almost 40% of the total volume area that merged cyc 4 5 6. That really explains why its always the last few cycs that blows up when ever is an engine failure.
This is what they are like now, with the top half milled, lumps cleared out, and I'm going to weld steam pipe over the top to increase the overall volume of the manifold log.
Very nice, photos really help show the progress your making :)
Will these be done on an exchange basis or will you have stock?
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
