lol ramps a little steep, 150-330kw in 700rpm
He explained why that is. It's a 9 second ramp as he is concerned about the stock internals holding up to such huge power.
It would make for an interesting drive, however :)
Wouldn't a shorter ramp actually make it look laggier on paper since the dunno allows the rpm to climb faster?
yes Trent wasn't very confident with stock con-rods when we got to around 375rwkws, faster ramp puts less load on to the engine, and generally result that sort of power curve. I was hopping for 400rwkws at the time ;) .
On road its obviously not as responsive as the SS1PU or the SS2, but pulls crazy after 4G on full throttle. I'm putting the SS2 back on for the final tune based on external gated setup and e85.
My ss2 is booked in at allstar garage in 3 weeks. Running it in between now and then once brake pads arrive. Hopefully have a drive this weekend
The turbine housing used on that run is a .82 type B rear. I believe type A would have produced more power. How ever this is the first prototype that made into this sort of power range, so there are many areas that could be twicked for even better result.
I think G3 will max out around the 370rwkws mark based on the same setup. I will do a test based on it in the next few weeks. I've also got few idea on high flowing factory R33 and R34 turbos that I like to trail.
Further evaluation on the SS2. it made 337rwkws on e85 externally gated at 18psi peek just touching 20psi. I've also trailed it based on internal gate running boost controller and straight off the actuator.
The solid red and green are from internal gate, Green is internal wastegate pressure:
Boost curve for all runs.
My ss2 internal gate turbo is ready to be picked up tomorrow.
Going to installed on a healthy rb25neo, ID 1000 injectors, z32afm, Hybrid turnflow intercooler with one of Scotty's metal intakes.
Will be tuned by Trent at Chequered tunning.
Will post up results when everything installed. Probably sometime in the next month
Ooo, nice one Tony. e85 I hope?
Nah not e85. It's my daily and I do alot of road trips on weekends.
So don't like the idea carrying jerry cans in the boot everytime I need to travel.
But yeah ID 1000 injectors just in case I ever change my mind in the future :P
It would be interesting to see what your G3 style hi-flow(PU?) did on a stock exhaust manifold and E85,
eg ..most power for a full stocky look
cheers
darren
hypergear can machine the stock rb t3 inlet cover to match up and bolt onto the ss series of turbos which means stock looking turbo
Edited by Dan_J
Yes can run stock comp housings on those.
Some updates with factory exhaust manifold fabrications. Well yes it is a not an welly engineered part. The port don't match up with the head as we already known, they had huge lumps in side the collectors, looks like they were trying to seal the bolt holes when the bolts aren't fastened. The lump took almost 40% of the total volume area that merged cyc 4 5 6. That really explains why its always the last few cycs that blows up when ever is an engine failure.
This is what they are like now, with the top half milled, lumps cleared out, and I'm going to weld steam pipe over the top to increase the overall volume of the manifold log.
Very nice, photos really help show the progress your making :)
Will these be done on an exchange basis or will you have stock?
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
