Here it is. SS1PU internally gated bolton version for S13 SR20det non vct.
The thin red line is on stock cams, while the thick red line is on big Tomei Pro 270 dur cams which made it bit laggy. The tune is based on pump 98.
How much is this turbo and what's needed to bolt on just 3inch intake and oil line ?
The car's not 100% done at this stage, my expectation sits around the 280rwkws with bit more boost once all finished.
The I have two stock manifold that I can work around with. It will have to be on exchange basis. means I will hold a deposit for the donor manifold till stock manifold is received. Or just send in an donor manifold to be worked with.
The billet SS1PU for SR20det is retailed for $1000 including actuator. It can be built as a OEM bolton turbo for S14 or S15 (benjo fitting) with factory comp housing, It does not require after market oil lines, and certainly do not require and external gate to perform. How ever oil line is only required when fitting onto a S13s.
Sounds good, Look forward to seeing what pricing/packages you can do with the modded stock manifold.
Will be after a G2 of some sort and a manifold whenever this project is finished :)
Also since stock manifold is a twin plus log manifold, I would prefer to keep the way it is specially when its no longer restrictive. So external gates can be added to the turbine housing like:
But unless its been worked, External gate would still perform better when fitted on to the manifiold.
Sweet will be keen on getting one if I get a s14 so built with bolt on housing
So there built with billet compressor wheel so should handle big boost how much you think?
30psi I'll like to try it on e85 crack 300rwkw ?
At moment you will be looking to spend $500 to get one done on exchange basis. and that is very little money for the amount of work involved.
I'm taking about in a sr not rb but this thing has billet compressor so stronger and lighter
I'm talking about a VQ not an RB.
Why would the engine matter? The turbo will pump X amount of air, and if there are no restrictions any engine should run around 300 on e85 with an SS1PU, maxing out the compressor.
G'day,
i have a ATR43 .63 on a RB25 in a 32, it has 3" TBE, 750cc injectors and a warlbro, at 17psi it punched out 302rwhp and my tuner informed me the next step is a bigger turbo.
any other suggestions for extra power? Cams? i dont want to go down the E85 route as its not readily available at the pump here.
I need to know the turbo's profile, been .63 it would should be a smaller G1, G2 or the older TR43 series. Also I need to know the date of when the turbo was purchased. There has been many updates made since.
Generally they need to have a large metal induction pipe, free flow exhaust and a good tune. assume those are at presence I would dump bit more boost, and that should make it into around the 350hp mark assume it is a G2 profile. External gate also appears to work well in combination of factory exhaust manifold.
Depending on the hp you are chasing for, larger .82 rear housing is recommended for any thing above 350hp. and those can be made to suit your current turbine wheel.
Also just noticed you are located in Perth. If that is the case I recommend getting your tune checked at All start garage.
How much will it cost to stao to have a gate supplied and welded onto my internally gated tr43i?
The gate I can supply at $200, welding and machining and materials is $300. So all up is $500. you need to adjust the screamer pipe off the gate a little as I don't know how much exhaust clearance you might have.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
