I just brought a hypergear turbo and i have heard from people they say if you use a 3inch metal intake on the cold side of the turbo it gets the most of the power out of the turbo?
Anyone know anything about this? If so some info would be great and what i need to do it? I think there is a link on the hypergear page if anyone has it could they post it up?
Cheers
Well depends on the turbo. Intake pipe should ideally be the same size as the inlet to the turbo. So if you've got one with a 3" compressor inlet then 3" intake pipe will do, if you've got one with a 4" inlet then ideally a 4" intake pipe would get the best results. Not sure what you're asking for with "what you need"? You need some pipe and some welding skills if you want the PCV and BOV returns?
All been covered in this thread before though.
You can get Scotty or Abe2 to make an induction pipe. check page 264
Or if you have a Adaptronic or a map sensored ecu I would just run a 3inch metal pipe with a 45 degrees silicon hose and a pod.
Check page 89
You probably find all your answers on page one, I've labeled all the important discussion bits in reference and linked to according pages.
Interesting that they didn't use any correction method, I've never had a run on Allstar's dyno without SAE being used.
They only put correction on to make people feel better their car made shit power...
To my understanding that the correction method makes the HP reading true in situations that would alter the output of the actual performance levels. It is calculated based on humility, air density, temperature, and altitude. Without correction the result could significantly differ depending on surrounding environment, but not necessarily only to a more positive or negative extend.
As If I knew the dyno has no corrections then I would want to have my car tuned at night when humility is low. air temp is cold with higher air density. :whistling:
Updates:
I'm getting some steam pipe bolton manifold and high mount manifold made overseas as I'm typing. I should have a prototype received by mid next week for trailing and testing. Those manifolds will be available for $300 to our customers assume they perform as expected.
It appears a larger turbine setups would perform better on factory manifolds, I will trail a SS2 in a .82a rear housing on current std manifold for some comparison.
Checked actuator pre-load which is about 4mm but rod isn't straight so might play with that next days off. The bracket for the actuator is on a very different angle to what is required so need to modify or bend it somehow.
It has to be in a particular angle as else the comp cover will hit the manifold. I've added few spacers under the actuator between the bracket. as long as the rod is perpendicular to actuator it self it will actuate fine.
But the rod isn't perpendicular. When disconnected it sits between the 2 pins. Might try modify it so it doesn't need the washers to space it off the bracket
Rofl. Told you guys, was tied down financially.
spent the majority of my weekend motor swapping 2 s14s, on my own, to fund this. Just so I could say, told you so :P
and I told you guys I make decisions fast once I can afford to :P
Me too! I watched the entire development of the SS1 and SS1PU in this thread, I know the genuine effort that has been put into it and I know what I'm getting.
On my way to the bank now. EDIT: ANZ the lazy pricks don't open till 9:30 so. I'll be paying for my turbo at lunch :P
This will be mega.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
