Being limited by injectors I'm aiming for 230 but have cams and gears so will try and dial it in at the lowest possible rev
I've spent couple of hours on a bridged twin actuator setup with some scraps I had. In theory once both actuators gets connected to a single boost source, the valve open pressure stays the same as having a single actuator, how ever the strength acting against the gate doubles. I hope I'm on the right track and my innovation holding boost steady through out the whole rev range.
Nice work Stao! Thats effectively the same theory as a 'big can' actuator. Hopefully the extra mechanical load works towards holding higher boost levels flat.
FYI to all readers: Payment for my SS1PU has been made! Can't wait to have my new turbo in my hands!
Its different to a big can actuator, I've used it while ago and I couldn't get rid of the boost drop, the current high pressure actuators worked better.
Big can or high pressure actuators will only work to certain extend, the stronger the actuation spring is the more boost spike occurance in mid range as exhaust manifold pressure at that point is not as high as what they are in upper rev range.
The Actuator is acting against both inlet manifold pressure and exhaust manifold pressure, The EBC can bleed off inlet manifold pressure how ever has no control over exhaust manifold pressure. Pressure at any points of its distribution remains constant, So in this setup the advantage of having two actuators halves the force generated through exhaust pressure.
The end result in theory should half the amount of boost drop or better. I've taken the car out for a thrash with both actuators hooked up in one boost source, they are now sitting at 18psi instead of 16psi on a single. So hopefully it holds 20psi flat on the factory exhaust manifold.
And who said you cant reinvent the wheel? ;)
If you get a chance please take some pics when building my turbo, for my personal build log :)
Car going on a local dyno just to compare boost plots with exhaust on and off tomorrow morning
Talked to head company who modified it. They said although squish pads were removed, de shrouding valves should be helping increase velocity and not create any lag and was advised to get an adjustable exhaust gear, dial cams in and see if it picks up earlier plus should be a bit more Det resistant now than before
Also found in another thread someone say they installed poncams and went backwards because head and block were skimmed so 0degrees wasn't really 0. Will bring a dial gauge home from work after my holiday
Edited by t_revz
im also worried about dialing cams im with the decking... Ive decked my block and dropping off my head to be decked today also. Running poncam type R's I hope it doesnt cause headaches..
My squish pads are removed plus other material in chamber yet after being skimmed previously then this time it's back to original CC so I guess it's been skimmed substantially all up, whereas the block only got trimmed 4"thou.
Tuner cringed this morning when I told him valve guides had been done... he said he'll see how the car goes on the dyno and push it as far as he's comfortable, but he said with the motor having been apart, and given its still on the stock exhaust manifold, he thinks it will be between 350-380rwhp.
Shall see how it goes!
LOL please dont tell us it pulls hard again until it is tuned.
last guy to get a HG turbo and see how hard it pulls, pre tune, blew his motor.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
