Being limited by injectors I'm aiming for 230 but have cams and gears so will try and dial it in at the lowest possible rev
I've spent couple of hours on a bridged twin actuator setup with some scraps I had. In theory once both actuators gets connected to a single boost source, the valve open pressure stays the same as having a single actuator, how ever the strength acting against the gate doubles. I hope I'm on the right track and my innovation holding boost steady through out the whole rev range.
Nice work Stao! Thats effectively the same theory as a 'big can' actuator. Hopefully the extra mechanical load works towards holding higher boost levels flat.
FYI to all readers: Payment for my SS1PU has been made! Can't wait to have my new turbo in my hands!
Its different to a big can actuator, I've used it while ago and I couldn't get rid of the boost drop, the current high pressure actuators worked better.
Big can or high pressure actuators will only work to certain extend, the stronger the actuation spring is the more boost spike occurance in mid range as exhaust manifold pressure at that point is not as high as what they are in upper rev range.
The Actuator is acting against both inlet manifold pressure and exhaust manifold pressure, The EBC can bleed off inlet manifold pressure how ever has no control over exhaust manifold pressure. Pressure at any points of its distribution remains constant, So in this setup the advantage of having two actuators halves the force generated through exhaust pressure.
The end result in theory should half the amount of boost drop or better. I've taken the car out for a thrash with both actuators hooked up in one boost source, they are now sitting at 18psi instead of 16psi on a single. So hopefully it holds 20psi flat on the factory exhaust manifold.
And who said you cant reinvent the wheel? ;)
If you get a chance please take some pics when building my turbo, for my personal build log :)
Car going on a local dyno just to compare boost plots with exhaust on and off tomorrow morning
Talked to head company who modified it. They said although squish pads were removed, de shrouding valves should be helping increase velocity and not create any lag and was advised to get an adjustable exhaust gear, dial cams in and see if it picks up earlier plus should be a bit more Det resistant now than before
Also found in another thread someone say they installed poncams and went backwards because head and block were skimmed so 0degrees wasn't really 0. Will bring a dial gauge home from work after my holiday
Edited by t_revz
im also worried about dialing cams im with the decking... Ive decked my block and dropping off my head to be decked today also. Running poncam type R's I hope it doesnt cause headaches..
My squish pads are removed plus other material in chamber yet after being skimmed previously then this time it's back to original CC so I guess it's been skimmed substantially all up, whereas the block only got trimmed 4"thou.
Tuner cringed this morning when I told him valve guides had been done... he said he'll see how the car goes on the dyno and push it as far as he's comfortable, but he said with the motor having been apart, and given its still on the stock exhaust manifold, he thinks it will be between 350-380rwhp.
Shall see how it goes!
LOL please dont tell us it pulls hard again until it is tuned.
last guy to get a HG turbo and see how hard it pulls, pre tune, blew his motor.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
