Hey Stao - if my AX53B70 ever goes kaput do you think you could make something up for me with the housings off it? It looks like it could do with a couple more mm in the both the compressor and turbine wheels. So far it has been nothing but rock solid but I only use at 1bar max. Thought I'd ask as I wouldn't mind pushing it a bit more.
I'm only looking for 250-260rwkw, I figure the turbine housing on this would be ideal for that power level.
Edited by simpletool
Yeh well I wouldn't expect it to be a hell of a lot, but considering I'm chasing a restriction in my setup somewhere, I just want to know that everything is as good as it can be.
Run it without a dump pipe :whistling:
The problem with large internal gate is boost control. means it will have more boost tappering off in general as there will be more load on the actuator. It is a bit of a concern on the new .82 IW housing assembly, might need to run a 2~3 actuator setup or some thing similar to eliminate boost drop.
one off 38mm internal gate SS1 turbine housing.
Have big gate keeps the turbine housing cooler, but harder to boost control. how ever also depending on applications, we do get XR6 BA turbo waste gate jobs often. From my past experiments bigger gate drops more boost. How ever that was before the innovation of all the wastegate controlling methods that I've used today, So might not have the same drop behavior, while makes more power on lesser boost just like having an external gate.
And yes the machined 3inch Vband adaptor fits All .63 and .82 ATR43 series.
With way too much time on my holiday in Japan to catch up on some reading and not spending as much as anticipated etc I've made a list of jobs to do hopefully before end of the year.
Buy an Adj ex gear and dial in both cams as they are both currently retarded.
Modify or change dump pipe til it matches turbo perfectly. Awaiting Stao's results currently on new v-band piece.
Quieten down rest of exhaust
Section off pod filter and set up a cold air intake
Swap internals of plumb back BOV as I blocked atmo port but it keeps reverting. Need recirc port to open first.
Gas up air con.
And for good measure install WMI :whistling:
Will order bits tomorrow so it starts arriving as I get home :)
We were able to round down the edges right up the gasket.
But unable to open her right up as the walls were getting thin.
Yeah prob only 10mm
She'll be right! Still much better than before!
Should get tuned by Trent next week so will see how the results go
Please let me know your date, I would like to come and witness your tune and take some video footages. cheers
No problem will do!
Getting a mechanic friends to do the work out of hours so could be a one or two weekend job, pending if things go to plan or if we have time.
Haven't booked at exact time with Trent yet but he said he could squeeze me in any time. But will let you know!
Did you get a genuine nissan gasket from JJR for the dump pipe too Tony?
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
