Hey Stao - if my AX53B70 ever goes kaput do you think you could make something up for me with the housings off it? It looks like it could do with a couple more mm in the both the compressor and turbine wheels. So far it has been nothing but rock solid but I only use at 1bar max. Thought I'd ask as I wouldn't mind pushing it a bit more.
I'm only looking for 250-260rwkw, I figure the turbine housing on this would be ideal for that power level.
Edited by simpletool
Yeh well I wouldn't expect it to be a hell of a lot, but considering I'm chasing a restriction in my setup somewhere, I just want to know that everything is as good as it can be.
Run it without a dump pipe :whistling:
The problem with large internal gate is boost control. means it will have more boost tappering off in general as there will be more load on the actuator. It is a bit of a concern on the new .82 IW housing assembly, might need to run a 2~3 actuator setup or some thing similar to eliminate boost drop.
one off 38mm internal gate SS1 turbine housing.
Have big gate keeps the turbine housing cooler, but harder to boost control. how ever also depending on applications, we do get XR6 BA turbo waste gate jobs often. From my past experiments bigger gate drops more boost. How ever that was before the innovation of all the wastegate controlling methods that I've used today, So might not have the same drop behavior, while makes more power on lesser boost just like having an external gate.
And yes the machined 3inch Vband adaptor fits All .63 and .82 ATR43 series.
With way too much time on my holiday in Japan to catch up on some reading and not spending as much as anticipated etc I've made a list of jobs to do hopefully before end of the year.
Buy an Adj ex gear and dial in both cams as they are both currently retarded.
Modify or change dump pipe til it matches turbo perfectly. Awaiting Stao's results currently on new v-band piece.
Quieten down rest of exhaust
Section off pod filter and set up a cold air intake
Swap internals of plumb back BOV as I blocked atmo port but it keeps reverting. Need recirc port to open first.
Gas up air con.
And for good measure install WMI :whistling:
Will order bits tomorrow so it starts arriving as I get home :)
We were able to round down the edges right up the gasket.
But unable to open her right up as the walls were getting thin.
Yeah prob only 10mm
She'll be right! Still much better than before!
Should get tuned by Trent next week so will see how the results go
Please let me know your date, I would like to come and witness your tune and take some video footages. cheers
No problem will do!
Getting a mechanic friends to do the work out of hours so could be a one or two weekend job, pending if things go to plan or if we have time.
Haven't booked at exact time with Trent yet but he said he could squeeze me in any time. But will let you know!
Did you get a genuine nissan gasket from JJR for the dump pipe too Tony?
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
