I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
Cometic plenum & manifold gasket are both steel :thumbsup:
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
Power coming at ya.
Just bought water meth for my SS2 so maybe ill see you in mine....unless your going on e85 :(
No e85 here
My car is still my daily
Would like to be able to go on road trips without 6 jerry cans in the boot :P
Hence me using water meth.
Tank should last 1 tank of fuel on the track or 3 months on the street :)
On this note I have a nice little kit I would like to sell ;)
Come at me bro!
I looked long n hard and thought about hitting you up but unfortunately and no offence but it was my least preferred kit.
Each to their own, but thanks for helping my cause :P
I had planned it for a very high comp DE+T setup, but since then went about forging my DET instead.
So its fairly redundant to me now as my SS1PU will do what I want it to do without the WMI.
Hey Stao, do you have a comparison dyno graph of the G3 with original rear housing flange and the type B one I got from you?
Goto
www.hypergearturbos.com
Under ATR43 and there are dyno readings from both Type A and Type B rear housing from the G3.
Goto
Thanks. If I'm changing from type A to type B, do I need to get a new gasket of some sort for the new flange to go on? I just want to make sure I have all parts ready for the swap over.
I'll have a new dump pipe gasket & new dump pipe, so I mean between the turbo rear housing and the flange plate itself.
Edited by copycutter
LOL thats a good idea. In practice I am told its like having E85 on tap - which helps those who don't have the stuff available.
For me my entire car hits a whole other level of money, time and effort at anything above 240kw. So instead of going for my ultra responsive 10:1 CR 240kw on WMI I have gone for an SS1PU with a DET motor instead. I think I will still get what I want with a little less off boost punch.
The WMI kit would make my setup even better Im sure, boosting power to 280odd shouldnt be an issue.. But the issue there is that SR gearboxes arent so 280kw friendly and neither is my near new clutch. So rather than reinvent the wheel I have worked so hard to create I am just going to enjoy my 240 kw and sell the unused WMI kit.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
