I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
Cometic plenum & manifold gasket are both steel :thumbsup:
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
Power coming at ya.
Just bought water meth for my SS2 so maybe ill see you in mine....unless your going on e85 :(
No e85 here
My car is still my daily
Would like to be able to go on road trips without 6 jerry cans in the boot :P
Hence me using water meth.
Tank should last 1 tank of fuel on the track or 3 months on the street :)
On this note I have a nice little kit I would like to sell ;)
Come at me bro!
I looked long n hard and thought about hitting you up but unfortunately and no offence but it was my least preferred kit.
Each to their own, but thanks for helping my cause :P
I had planned it for a very high comp DE+T setup, but since then went about forging my DET instead.
So its fairly redundant to me now as my SS1PU will do what I want it to do without the WMI.
Hey Stao, do you have a comparison dyno graph of the G3 with original rear housing flange and the type B one I got from you?
Goto
www.hypergearturbos.com
Under ATR43 and there are dyno readings from both Type A and Type B rear housing from the G3.
Goto
Thanks. If I'm changing from type A to type B, do I need to get a new gasket of some sort for the new flange to go on? I just want to make sure I have all parts ready for the swap over.
I'll have a new dump pipe gasket & new dump pipe, so I mean between the turbo rear housing and the flange plate itself.
Edited by copycutter
LOL thats a good idea. In practice I am told its like having E85 on tap - which helps those who don't have the stuff available.
For me my entire car hits a whole other level of money, time and effort at anything above 240kw. So instead of going for my ultra responsive 10:1 CR 240kw on WMI I have gone for an SS1PU with a DET motor instead. I think I will still get what I want with a little less off boost punch.
The WMI kit would make my setup even better Im sure, boosting power to 280odd shouldnt be an issue.. But the issue there is that SR gearboxes arent so 280kw friendly and neither is my near new clutch. So rather than reinvent the wheel I have worked so hard to create I am just going to enjoy my 240 kw and sell the unused WMI kit.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
