Well if you run stock manifold (or Brae bolton) with a .70 size housing it will find fine with a 15mm spacer even running internal gate, but its a pain getting the bracket engineered that clears every thing. Some thing in this size I would be recommending running it in a proper exhaust manifold, its not going to perform at its best other wise.
For the Stagea with the Neo motor, the best option is to just high flow the factory turbocharger. We can run a SS2 billet chra init, which would have very similar response as stock, but be able to handle much higher boost level and capable of around the 260rwkws mark used as a bolton turbo.
the 5558 would be .60 3076 in size would it not?(thats what it looks like in pics) , bit smaller than the .70's
All PT 4" covers are the same. You can order them in various sizes but if u order an SP cover (like everyone does) its the same 4" item for 5558 as it is for 6262
Some further updates on building the TD06/67 test rig. Car is now fitted with a Brae high mount manifold with our own 50mm external gate plumbed back with a 4inch exhaust exhaust.
Looks good. It did not come with a cheap price. All including the exhaust manifold, screamer, dump pipe plus installation comes to $1880 plus $250 for the external gate, including the turbocharger this kit comes to: $3230
How ever there is a very noticeable gain in mid top end torque without noticing the lose of response.
I will use this test rig to trail all the TDxx as well as the existing ATR43 turbochargers. This setup should provide the best possibly environment for the performance of any turbochargers, and is whats expected on a welly built track car. The end results will vary if components of the setup is differ.
Externally gated turbochargers are cheaper to produce.
I found this pretty informative to read, it had descriptions about different types and effects of manifolds.
http://www.turbobygarrett.com/turbobygarrett/log_style_vs_equal_length_manifolds
It's auto, so I'm trying to minimize the 'lag'...
What are the options for a larger internal waste gate but maintaining the dump stock flange?
Cheers
Justin
Yes you can run the SS1PU version, that is zappy responsive and makes around 260rwkws in a Rb25det on a manual. I can also high flow your stock comp housing to the body of that turbo so every thing looks stock standard.
e.g. my standard looking 260rwkw engine bay! Never has surface rust and grime looked so good :)
Would look the same with an E85 tune for close to 300 :D
You can have one intake mod, so it's technically legal, but the combination of that with the front mount isn't.
It just sounds too good to give it up :(
Birds I thought you had stock housings on both sides, didn't realise you had the actual FNT rear housing. That's cool.
I think stao was saying the ss2 in all stock housings for the stagea. I'm sure that would be awesome yet I'm not sure that would meet the request of faster spool than stock. That was an interesting ask lol
So I installed my z32afm and Bosch EV14 ID1000 style injectors last night.
Just curious who has installed these mods and run their car? From what I understand & have read the car is supposed to run like dogs balls once its installed without a tune?
As after I finished and gave the car a start up she idled perfect like stock lol
Hahaha wow tony!
What kind of computer are you running or still the stock one?
Running a Nistune at the moment previously tuned by Trent @ Chequered Tuning
Just curious to see how other cars have run :/
It will start an idle fine...mine did..you can even rev it..
now try drive it around the block and report back :D
Actually you better not...I did and barely made it home..its fine cause its just on idle, its not really dumping any fuel In...put it under load and it will open the injectors up, flood and foul your plugs in no time...
So I see
Makes sense :D
Edit: What about the z32 afm? Shouldnt the computer go a little funny with that installed to? Or does it idle fine but when i drive it something will happen too? Not that I will. Just curious
That's what I'm looking for... maximum zappiness!!! This car needs to be all about strong low rpm torque figures and response... don't care about the top end (that's what my twin td06 gtr is for). I'd be more than happy to end up with a turbo running 16-18psi, spooling faster and making more low end torque that the standard turbo and toping out around 210-220rwkw.
I have modified the auto, so there should be no problems handling the extra torque.
I'm also planning to tow with this car.
Stao can you shoot me a pm with a price for the SS1pu (in my stock turbo) or any other better options.
Cheers
Justin
Edited by XRATED
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
