cant be intake restrictions, 4" intake with K&N pod, 3" custom IC piping....motor was running standard turbo before and was pretty stock..
The car feels good, it has brand new 255 federals on the back and it breaks traction when it hits boost in second, used to do it in 3rd with the old tyres..
Heaps weird...
What ecu? No changes with fueling and timing makes you wonder if the changes are being written to the ecu.
Nistune was playing up like this on the Stagea last year with this sort of issue.
power fc... the changes were definitely writing because the wideband was registering the changes and the timing eventually caused the knock levels to increase slightly as well...
Hypergear turbos love restrictions :laugh:
I feel your pain though. Car has been sitting in the shed for a couple of months now, thinking about what it's done :glare:
Has it learnt its lesson yet?
Apparently not, it hasn't fixed itself yet. Now it's throwing a tantrum with the drivers seat, so it's in the naughty corner until I get back from Europe.
we both had no idea.... the car wasnt responding to anything... threw more timing= same power, richer=same power, leaner=same power wtf?
That means turbo's pushing some thing's limit which power band does not responds to the tune. I think its in the exhaust or some where, try drop it and see if any thing changes. Was it a plumb back external gate?
Normally cooler restrictions would drop heaps of boost, and the cooler would be burning hot on the cool side. So its not the case.
Also if you are in Sydney might be worth while visiting Toshi for a quick check up.
Why is the engine speed increasing then going back to zero? But speed increases gradually
I could be way off here but that torque looks quite high compared to power so maybe its getting wrong speed signal?
Rpm increases,decreases,increases then falls off
Edited by t_revz
yeah the dyno guy said that for some reason some nissans do that weird shit with the rpm... he said it wouldnt affect anything but.
The power graph really supprised me because it feels nothing like that...it actually has nothing for ages then all of a sudden kicks in massively and frys tyres but that graph makes it look very linear.... very strange
Just got off trents dyno
265rwkw with coil packs missing all over the place
19.7 psi down to 15.7 psi drop
Trent thinks it will hit close to 300rwkw once we sort out coilpacks and boost drop
Internal gate, note sure about the extended arm? Im guessing so.
Retune booked it for next Thursday.
Have purchased yellow jackets and will put in new spark plugs for the tune.
Trent made a suggestion that the boost drop maybe due to the stock BOV on the GTT not up to task? But were not 100% yet until I do the coilpacks and go back in for a retune.
Anyone know what the power limit on the stock BOV is before you need to be concerned?
He said to get a GTR one if it is the case.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
