My turbo turned up while I was away at work, didn't even know it was on the way :P
Thanks Stao for all the help you've given me through this process, turbo looks good and can't wait to see how it goes. Now just have to finish my engine
I only have the standard highflow which is good for 430hp.
270x1.34= 361rwhp
361*1.2=434 engine hp allowing 20% drive train loss (which is a widely accepted rough estimate)
Yours sounds about right,
Is that v-band???
V-band rear? yes
3.5" V-band
I will take some more photos in a minute, that was just a quick camera phone photo last night when I got home from work
Very nice looking turbo, Not sure if I want to paint the housing or not lol
No im just wondering,
anyways i got it retuned this morning again and because of timing and it was sort of pinging my tuner had to back the power off, now its on 255kw on 18 psi, i'll post the final tune tonite when i got a chance, im happy with the turbo either way.
V-band rear? yes
3.5" V-band
Very nice. I need one of these V-Band rears :woot:
That was my ceramic roller bearing highflow with a .60 comp housing :yes: and new externlly gated through turbine housing.
its pretty interesting seeing the 6boost's manifold has very long runners. any one can share some theory in doing that?
Equal length runners and merge collected so exhaust gas gets to the Turbo in equal/even bursts isn't it?
Pretty keen for this engine, really hope I can get the ext gate to work but think life won't be so bad if I have to go int gate I don't think
Need to trim the Turbo studs as one of them is fouling but other then that I'm very happy with how its looking :)
V-band rear? yes
3.5" V-band
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
Hi Stao,
Long time no speak! As you already know, I'm currently running a top-mount Garrett GTX3076R but looking to return the car to stock-ish to sell and was wondering what the boost response is for the hi-flowed R33 standard turbo and the hi-flowed R34 turbo like compared to the stock R33 turbo.
    • How much ya asking drunkan
    • A few other things to round out the chassis mechanical checks. Diff is nice and full of new oil, pretty sure it is Castrol VMX (I run the same on Award's recommendation). I didn't pull the cover to check, but I'm 90% sure the diff centre is a nismo mechanical (old school, not the gt pro). Gearbox is also nice and full of fresh oil, not sure what it is but not redline. Tailshaft bearing looks OK and a tailshaft loop is in place
    • Front lower control arm is standard with new ball joints, tension rod looks like JJR spherical. Front upper control arm is standard with adjustable bushes in the outside end     Rear arms are all nismo, surprisingly all the bushes at either end look standard but in good condition Subframe has standard bushes with lock collars HICAS has a lock bar with standard ball joints at the hub end
    • Next, shocks/springs/swaybars It has Sydneykid valved Bilsteins with HKS pillow ball hats all round. Springs are Eibach race springs on adjustable height platforms, with helper springs in the rear to stop rattling. These are 250 all around but easy to change for something else if required. Swaybars are powdercoated blue but would be Selby's/Whiteline solid adjustables, 21mm rear and 24mm front. Bushes and links in good condition All in good condition, no sign of leaks/damage etc
    • yeah for sure.....remember to put your tools away at the end of each day kids!  Actually it has been kinda nice working on the car, lots of memories of good times. I can pretty much hear him telling me off for stuff still.
