Yeah as above, it depends on the cams. For all intents and purposes, as far as you're concerned you won't lose VCT. I don't think there's any point whatsoever putting any cams in the RB25 for testing purposes that don't retain VCT. 256deg Tomei poncams seem to be the best and most common cam upgrade for mild/street RB25s, and I believe they retain VCT. Not NEEDED, but they fatten up the midrange.
Got the Fnt turbine ended T67 dummy fitted today, and went for a little test cruise with my current SS2 tune.
I personally recon its pretty laggy for every day road use. It does have very decent top end, but its down in power and torque mid range. on 22psi In 3rd foot to floor its starts to pull really hard from 4500RPMs all the way to 7200 limiter. With limiter at 8500RPMs on tracks its probably alright, I think I will be seeing close to 400rwkws on my next tune. Since the the FNT housing is in .82, the smaller 10cm turbine might produce better response.
I got a overlay print on my final SS2 run, This graph explains about the missing mid range very well.
Blue is my last .70 SS2 bush bearing high mount Ex Gate
Red is .60 SS2 Ceramic roller bearing ported stock manifold internally gated
Pink and orange is 10CM T67 on high mount Ex Gated
All running E85
Seems to be what most people are getting out of E85 from the dynosheet section, even Simon's T67's not showing true potential till 7000RPMs+, there is no match in mid range power and torque to SS2.
Seems to be what most people are getting out of E85 from the dynosheet section, even Simon's T67's not showing true potential till 7000RPMs+, there is no match in mid range power and torque to SS1PU.
fypbrah
Tao, u change turbo's every week :)
Yes, and high mount made it easier, all back to the SS2 now :P. I should be hitting up strips more often.
Most of customers are using it for road, I would prefer turbos with very good power and torque within usable rev range on stock cams and cam gears.
Making the external gate billet SS1 and SS1.5 at moment. They should be super duper responsive on road.
2ndly do you guys get up really early or never to go bed at all?
That is my T67 result, and yes it is on E85.
I am running a Greddy style plenum which on all accounts results in a loss of torque.
But that SS2 really does look amazing. 600Nm from an RB25 is insane.
Hey stao, just out of interest; how much would it cost to convert my ATR43G3 nissan 6 bolt internal gater to this current SS2 nissan 6 bolt internal gater?
Haha, about time :)
New comp wheel and comp cover only ;) the rest of it is reused.
Shouldnt cost much but should be epic as all fek.
Wasteland does not sleep.
But then again do you ever sleep & when you do are your dreams about turbos?
No I dream about hot chicks licking my turbos :P
To do that we need to:
Sleeve and re-profile the comp housing and back plate: $150
Compressor wheel: $200
Balance & Assembly the CHRA assembly then the turbo assembly.: $70
Total: $420
It will becomes a SS2 in .70 comp housing used on the test car with Nissan IW assembly. It won't be able to unleash its full potential till fitted with a proper exhaust manifold and externally gated plus a good tuner of course.
Some updates on the new billet SS1 and SS1.5:
I've had both housings machined to suit the core.
They will be using a SS1PU's externally gated turbine with 3inch outlet. This housing was customized to suit my current front pipe that was made for the SS2, so looks bad after been chopped and welded it few times but I got it fit on the end.
All fitted up and ready to go. will do some road tests tomorrow.
How did the new born perform? better then my SS1PU?
Edited by petero'nell
Well I can't really do much till its tuned. This turbo has a totally different rear wheel and housing compare to the SS2 so I'm not very confident flooring it at this point. How ever I did let it on 12psi external gate pressure and its very responsive and probably due to the effect of the external gate and manifold the torque was incredible.
Driving wise it feels like having a R34 turbo on a R33, turbo comes a live with just a little bit of throttle, ie tap 20% throttle and the turbo whistles to boost, floor it = a very big pull.
There are generally two kinds of feed backs, its either this car's got some serious power or this car is very fast. I think All SS1xx series belongs to the 2nd category. I've swapped the SS2 back on so I can drive the car, will post results for all turbos once Trent gets back from overseas. at moment I'm modifying the 10cm turbine housing to suit my front pipe, be interested to find out the on road behavior of my billet SL2 20G and 25G on Rb25det.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
