guys FYI the following is 400 bucks delivered:
http://www.ebay.com.au/itm/261045441228?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1390wt_1397
that is a GTR item which will work on any 240mm push type nissan clutch, RB25/SR20 included.
the clamp load is 1100kg so 300kw shouldnt be an issue. drivability will be as close to stock as possible.
hope that helps, NPC are good but you will be stunned @ the price.
Hey Scott,
I think those are the Exedy HD (re-manufactured pink cover ones). The Exedy Sports (silver cover) are the ones you want, the pink ones are terrible, I have had one before uneven wear on the friction plate not to mention you often hear people complain about them on various forums. And pedal feel of Exedy vs. NPC, Exedy pedal is super heavy not to mention people end up breaking pivots as well.
Hey Scott,
The re mfg pink cover is made in Australia, the rest of the world gets the japanese MFG silver cover item. That clutch is coming from the UK.
You can also tell by the box where it says 'exedy racing clutch' with Daiken logos. Where as the said pink cover clutch will come with the ghey 'sports tuff' box.
Excuse my ignorance, but is clamping load all that determines if a clutch can handle a particular power level? I would have thought power delivery, torque, driving usage type etc all affects it also??
The friction material itself obviously affects the amount of torque that the clutch can transmit. If you have a higher coefficient of friction, you get more grip out of the same clamping force. The detailed design of the clutch affects the way that the raw clamping force is distributed across the plate(s), which will also affect how good the clutch is. Simply think of that as the clutch being 95% efficient, or 85% efficient, depending on how well it uses the total clamping force available.
Clutches can be (and usually are) generally "rated" at a certain power level on a given engine because the diameter is essentially fixed across most clutches for that engine and the torque/power delivery variables are almost fixed. Move the exact same clutch over to some different engine and the rating might have to be tweaked. If you take driving style into consideration, then the "power rating" of the clutch assumes a perfect driving style and you would sensibly de-rate the clutch for any non-perfect driving (whether that be the usage model or the clumsiness of the driver, etc).
Yeh start doesn't affect mph much.
Well. Guess that explains our runs at Powercruise. Either we are both hugely down on power, or our turbos are extremely laggy between gear changes.
I say laggy between gear changes.
Im pretty sure if i got a good run i would most likely do around 14.1
Am i changing gears wrong? should i be flat footing the whole way and riding the clutch in gear changes lol???
101mph? That'd have to be a HELL of a launch etc to do low 13s or 12s off that, with slicks at least. 101mph is reasonably typical for high 13s/low 14s on a clean run. What power and type of car are we talking? With reasonable spool I'd be expecting under 200kw from an R33 - if it is much over 200kw then its not a driver issue, it is something to do with how the power is delivered (which could include how much power there is).
I will take mine to the drags after i get my turbo back from Stao and retuned. See how it likes ~6000rpm clutch dumps on MT's
thats it, teach that c*nt a lesson
hopefully i can borrow a go pro and can video me trying to rip the gearstick out the back window (as said by Jez himself on a prior test drive)
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
