thats a crazy result.. I like the way the torque stacks and fades off. I'd probably want that exact result for myself if I had an R33.
Is the CHRA in that SS2 core any different to the normal SS2?
22psi on e85 and shinnnnnnnnnning Dou dou dou dou
I will upload all the papers when I get a computer tonight. Doing it with my phone and it sucks.
Here is the dyno reading:
Boost:
Super responsive. Makes That about the same response as the SS1PU. Makes 17psi by 3500RPMs and about 100kws by 3000.
I will upload the videos shortly.
Video footage from today.
Surprisingly after multiple runs, the turbine housing or manifold did not turn red or overly heated. I guess this is the highest no. that a highflowed r33 turbocharger in factory housings has ever archived. This evaluation is pretty successful.
It how ever do cost $200 more then factory high flow option, for the extra work required on modifying standard turbine housing, as well as the high pressure actuator and SS2 billet compressor wheel.
I believe it is good for some where around the 280rwkws when used on stock manifold, internally gated on pump 98 fuel with good supporting mods and tune.
Yes the ATR43SS1 result of it on a Rb20det is on our site. SS1 billet version is updated version with better response. How ever I don't have a result of it based on a Rb25det.
Op6 should net around 370rwkws mark in this combination. I think I can get it close to 400rwkws with a different set of compressor profile. How ever it will be much laggier.
By the way, the SS2.5 is a CHRA made only for RB high flows, specially the 21U R33 housings. Won't be great used in normal housings.
I can also build the SS2.5 using the latest G3 comp wheel. Which will not add any costs to the standard profile while producing identical amount of power.
Standard high flow can get you a very responsive 250rwkws, while the SS2.5 or G3.5 can make more power will be laggy in the op6 rear housing.
I can do a special deal on the evaluation price of the G3.5. PM for further details.
Stao, that highflow is redonkulous.
What would that in an OP6 housing cost?
Every time I settle on a plan you go and do something that throws a spanner in the works....
I will do a special deal at $1160 including oil line. it might not be as responsive in the OP6 rear, how ever that should be reaching close to 370rwkws mark once setup on a proper manifold and gate.
Also releasing one more profile for the 21U turbine housing is the G3.5 This turbocharger is also a specific high flow built chra. it should produce bit more then the SS2.5. Hopefully be seeing towards 350rwkws mark. Its been pretty responsive using the 21U turbine housing.
Few other news is that I've managed to source some R33 copy turbine housings. That will help saving lot of costs building them here. I will pass on the savings and work out a cheaper alternative to high flows very soon.
  • Like 1
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
