had a retune @ garage 101 the other day
as it stands it has
3" TBE
ATR43 with .63 trim - 4" inlet pipe and pod
hybrid inlet manifold and low mount exhaust manifold
850cc injectors
walbro
new clutch
think thats it
366whp @ 17psi
That is a pretty good result for 17psi of boost. Tried boosting it more?
I was hoping for 260 :P or 270 ( theoretical max speed of r34 ) haha
The car will hit a brick wall before 260, depending on its aero. IIRC you need 6 or 700hp to break through the barrier without massive resistance. Not to say you couldn't hit 300 without 600hp but means the car will need a LOT more road post 260kmh.
I've felt this myself, over 250 was near impossible where it was actually motoring before it got there. Wasn't anywhere near rev limit or out of torque band either.
You are right, i still have rear spoiler, windscreen wipers/mirrors/not very aero font bumper
Only have 340 Hp aswell
But mabye my speedo will be out around those numbers and it might "look" like im doing 300 :P:P:P
I will still claim it :P
lost power at 18psi due to not being able to run as much timing.
was a good result i am happy and the car hammers, hard to get a good comparison due to changing manifolds, tuner and dyno in the one go.
This is one of the hardest strains you can put on your engine... I allways fitted egt monitoring for the standing mile and top speed events in the US when I was there. Might be somthing to look into
Your basically going to do the equivilent of 1-2minutes of running your car at full load on a dyno.
I'd be fattening up the tune to keep the egt's down.
Think oil coolers, lot's of taping up cracks and gaps, and getting the car loow... getting less air going under the car. At 250k/h you can raise the car up and inch or two. I'd go into it with a full tank too, just to keep some weight into the ass end.
If you have an aftermarket front bar, make sure it's secured by more than a couple of tech screws too.... anything going under the front wheels at speed isn't good.
I just wish we had a long enough, flat piece of rd in Tas to be able to do 1000m sprints of standing mile racing..
FYI
I am going to racewars (perth) and will be racing.
I guess ill be the first Hypergear Turbo to do a 1000 meter sprint?
Will be happening this weekend, hope to get as close to 300 as possible :):)
Will post my results up when im done :P
LOL didn't you trap 1/4 mile at mid 100mph?
You will be lucky to hit much over 200 let alone 300
We will see wont we.
Lucky to hit over 200? not really, getting over 200 is quite easy...
one of my traps was 176 btw
EDIT
Also since i was at the drags, i now have KU36 tires, i have replaced all my front bushes and fixed up some rear bushes
Replaced what i believe to be a leaking intercooler join, re programmed my boost controller ( more gain, less duty cycle )
Among other things, i believe the car can easily beat my shitty times before :P
Edited by jay-rod
what number in which run group? i may beat you to be the first to do the 1000m sprint :P
FYI
for reference Magic 1 on Antilag hit 230kmh at around 800m with a very strong headwind and he has 500+WHP
EDIT
EDIT
I would be guessing 210-220km/hr trap speed
Good result, now just bring it to Whoopass tomorrow and back up the numbers :P I'll be there in mine again.
EDIT
The leaking intercooler pipe would be the only thing that MIGHT affect your trap speeds. Otherwise the KU36's will slow you down (more traction = more friction = less speed).
There really isn't a lot you can do to improve your trap speeds without increasing power or decreasing weight.
Decreasing weight i can do
The KU36 will speed me up, my previous tyres were so bald i would barley get traction when i launched. ( way below the indicator ).
( if your talking the 1000 meter, then yes the ku36 prob slower than bald tyres, but i would rather be safe than dead :P )
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
