Isn't 8500 revving quite hard for a stock rb25? Have you tried with a plumb back to see if the inter-gear lag improves?
Its a Neo with valve springs and cams. 8500 seems to be the sweet spot.
I assume you mean plumb back waste gate? No I haven't, but I can't imagine that would help?
Might not, i always plumb them back anyway after on one of my cars i tested one to vent, plumbed in, and not fitted
at all, drove much nicer plumbed in , and seemed to have lotter better response after gear changes
cheers
darren
Did you not hear the the sphincter of the universe gobbling away in your engine bay on gear changes?
Lol!
No I meant plumb back bov. I have run mine blocked for the flutter noise ages ago for shits and giggles because the rb25 bov was leaking. Then when I could afford rb26 one I put that on. I think that no bov slightly detriments between gear response. I'll try get a video of mine up over the weekend of my boost gauge to show you.
Lol!
you are certain the rb25 BOV was leaking under boost? whats with everyone saying they are indestructible and can handle 11ty million psi?!
In that case no, haven't tried. Bov hasn't been on since I did the Plazmaman plenum. Need to get some piping made up, but my fabricator is no longer in the business :(
That's what my tuner was saying at the time. 25 bov was leaking during WOT on 98 tuning, so they blocked it to complete the tune. I then bought a 26 one, as that appeared to be the one that had the "bulletproof" reputation on the forums for big power/boost. No problems with it at all.
My searching on here told me the 25 one was suspect with anything above std turbo. I could be wrong.
Hanaldo from those video's you need to drive more agressively and keep it in gear for longer. Going into 5th is a waste of time on the strip. For example my first few runs were similar to those, wasn't revving all the way out/changed gear fairly slow then i changed my driving style and ran 7mph faster traps.
He said that he is revving it high and only changed to 5th after the line..?
What do you guys mean by driving more aggressive? Is he meant to be smashing it into gears
Hanaldo I think this is more the shifting they are talking about. I remembered this r34 they built back in the days of HPI dvd's.
Skip to 27:00 and watch the shifts. This is a 294rwkw r34.
Dyno tuning and chart at 25:30
Edited by copycutter
8500rpm in 4th gear changing to 5th? car would be doing ~220kph or so based on stock gearing. Don't think so, also gear changes are very slow and launch is very mild. Driver skill is more important than power, i raced an XR6t at WSID and was neck and neck with him the whole way down, not because my car is fast, but because he couldn't drive for shizz. When on boost he would pull a bonnet ahead then change gear ever so slowly and i would reel him back in and it would go back and forth to the finish line where he ended up doing 1 tenth quicker and only 3mph faster.
yeah i was going to say, is the tacho right? It sounds more like 6000rpm... and if you shifted to 5th just after you crossed the line then surely you crossed the line at over 7000rpm in 4th, which would be over 200KMH in an R34 anyway (120MPH) unless you have a 4.3 diff in it...
I got mine running again today. 3.6 diff in the bin and sporting a 4.11 and twin plate clutch now, its a completely different car.. traction is a nightmare. Im thinking when I go to the drags im not going to bother trying for a time, just gonna smash and grab for a MPH.
That's an interesting point, I don't actually know if my tacho is correct. But in any case the shift to 5th was well after the line, I didn't cross the line at 8000 in 4th. Don't really know what I crossed the line at, possibly around 6000. I just keep it going after the line just in case :P
Mmmmm I just watched the interior video again, that shift to 5th can't have been as far past the line as I thought. But it was I only time I did it, do I don't think it had any effect. That was actually one of my quickest runs.
One thing I noticed when I was going from my car with the gate plumbed in to atmo. I used to shift earlier with the atmo gate as it sounds like you are ragging on it so much harder when you are not. With it plumbed back I would hit the limiter more often. Strange but I suspect based on where its cracking gate in 1st gear that you are shifting somewhere well under 7,500rpm and depending on your curve you could be starting off in the next gear with 60rwkws less then if you used an extra 500rpm before shifting.
You really need to look at your power curve and gearing and work out the optimum revs for average spread of power. I know I had to rev my RB20 about 1,000rpm harger to have a real difference in power with the Plazmaman as under 5,000rpm it was generally lazier. So I used to hit about 9,0000rpm in 1st and every other gear about 8,300-8,500rpm to make sure it stayed on the boil
Maybe if you have a I phone or something, theres maybe a car style G-meter program /accelaration measuring app that you could use
to plot gear changes based on on g force or something( i don't know,just thinking out loud)
cheers
darren
Hey man going to be going to wsid on Sunday for the off street meet if you want to come should be good also no rush like wednesday nights cause it during the day
You should be in the 12s easy just try and get good rubber
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
