This is recent and yet interesting result sent in from a customer running a SS2 turbocharger with a R34 GTT Auto. It was used as a bolton replacement internally gated.
It has:
Blitz front mount return flow cooler
1000 cc injectors
255 pump JJr front pipe
Z32 AFM
Nistune
E85
Stock Auto with a transmission oil cooler
300rwkws @ 17psi of boost:
So car is booked in for a tune on thurs. previous tune was 345rwhp on 17psi with the now outdated ATR43G3 type A internal gate. Now has the later version with the updated comp housing i think, ball bearing cartridge and type B housing (thanks to Stao for uprading me for free!). Tuner has recommended to block off the BOV after i asked if the stock one could hold 20psi. Cant wait, havent boosted for about 3-4 months :(
  • Like 1
Its extremely important remembering to preload the actuator as the tuner's tuning. keep on preloading if are seeing boost tapering off before the desired level. It might be 5mms or could be 15mms, the more you load it the higher up top boost level it will hold, more boost makes more power.
4-5mm preloaded on it at the moment. I've never had the boost tapering off issue, infact its been the opposite with mine, pressure increasing towards redline.
Good luck Landscribble, hope the kw's flow freely :)
I've got an g3 type A, so it's definitely possible to get a result.
Thanks, i hope aswell but now im not really fussed if it doesnt match Stao's results, aslong as i can drive the thing im happy. I know the turbo's can make the power having made 279rwkw previously by a different tuner, i chose to go the type B for a little faster response.
I preloaded mine Around 8 or so mms, With a 14 pound spring, it boosts to 23 psi, tapering down to ~20psi now.
I find it very wierd its even getting to 23 psi, ( boost controller is Off )
Does this mean to much preload?
Ah you could have bought my SS2 instead.....comes with R33 coupe :whistling:
I think its a good boost level. Usually the boost curve starts to spike then drop. with more preload it starts to hold, and if over loaded the boost starts to creep. Thats I usually adjust mine with internal gate.
Ill prob remove the controller all together then, as it might still be affecting it even plugged plumbed in.
It does feel alot more consistent when boosting now.
If youve got it able to hold 20 off the spring (peaking 23) that is really good.
Provided your car is tuned at that level I give you the big thumbs up.
Just watch it when the weather changes as that can make it jump :)
Car is tuned for 22 pound tapering down to 14-16 pound.
So....not really tuned now..
I will be getting a new low manifold/external gate soon so im hoping to hold of on a new tune until i get those.
Question: How do Dyno Tuners measure Boost ( pressure )?
Might be a dumb question, but just want to know how they measure.
Edited by jay-rod
hose in plenum
After having the car at a workshop for 8 business days and not tuned, and it getting put of , i went and drove it home on the nistune basemap.
Cars now booked in next thursday arvo to get tuned by Matt from nistune on a mainline dyno(apparently the dyno of truth so the young kiddies tell me..lol)
Going to tune it on 98 and wmi disconnected first and get the best out of it , then connect it up and go from there..
cheers
darren
Edited by jet_r31
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
