Remember mine is peaking at 25psi so it usually takes alil longer the higher the boost if you want to compare to yours at 20psi it gets there by 3600rpm
Only bad thing about it is it noses off abit after 6000rpm but might be sorted now due to the 4psi drop before now I got a 20psi actuator which seemed to fix it
Ah yeah true.
I'm keen for another visit to the dyno. Need to get my bugs fixed and I hope he's willing to squeeze 10/10s out of it now :(
So I will have to look at preloading my wastegate.
Can you purchase better aftermarket actuators?
From what I remember it was pinging at the 250 mark so was backed off slightly. Would it have the same limitation if I was to get it to hold the 20psi throughout the rev range?
Depends on WHY it was pinging, but more than likely yes - if anything worse.
image hosting 30 mb
Got my car tuned today. It's running an atr43g2.5 and made 250rwkw with boost hitting 21psi and coming down to 16psi.
The tuner was saying that if they tried to add in more boost they had to keep pulling timing so unfortunately this is how they had to tune it. Any ideas what may be going on Stao?
Was this on a high flowed unit? Its about the right amount of power for a g2 compressor.
It's a g2.5 type B also. It was originally a g2 I think but as blown so when I sent it to you you did the upgrades as well as rebuilding.
I'm happy with the power just wasn't sure why it seemed to need less boost at higher revs cause otherwise it would just ping. Comparing my graph to the one you have on your site:
http://www.hypergearturbos.com/images/dynosheets/atr43/atr43g3/60comp110512E85/power.jpg
Mine is very similar to the 98 power curve (green curve, yellow is e85) up until my boost starts dropping off. Would have been nice to wind a bit more in.
I was just thinking could my intake be the issue? I have a stock airbox with 3inch piping to the turbo. Was hoping to keep the car looking stock but if it's causing this issue i'd be happy to make a pod filter enclosure
Definitely not that part of your intake - generally if it's pinging with more boost, it'll be from combustion chamber temps getting high. This is either from exhaust back pressure, or perhaps a restriction in the intake AFTER the turbo (intercooler is the usual suggested culprit here). Either that, or the turbo is just being pushed beyond its efficiency.
Intake leak could explain it, too.
If its leaking from somewhere after the turbo you could see the boost drop you are and then work the turbo harder to keep up the boost, pushing the compressor out of efficiency and causing the ping.
Sounds like you are almost there, you just need to go over the setup with a fine tooth comb and iron out any small bugs.
Yeah, just thought of this too. Intake leak would put it out of efficiency as it's trying to overcome a massive hole lol
Shouldn't be back pressure I have a full 3 inch exhaust with hi-flow cat would hope that's not already a restriction. My fmic is a return flow ARC which isn't particularly big as FMIC's go but once again I'd hope it can keep up with under 300rwkw
Ah that makes sense to me will definitely check this out hope I don't need to take my intake off again that was a pain for doing injectors
Did you take off the top plenum to do the injectors??
If so, did you replace the gasket and did you clean the surfaces extremely well? If not, I'd say you should check there for leaks LOL
Mick_o had one of those leaks and it was a bitch to spot. Car wouldnt exceed 280kw.. Found the leak by running water over the intake manifold while it was doing 4th gear pulls on the dyno. Fixed gasket and WHAM 335rwkw.
Didn't clean it well or change gasket so yea sounds like my most likely place :(
He's right, the graph shown is for a G3, but the intake leak might still be present and causing the 5ish psi boost drop. Fixing it might get him another 10-15kw from threshold to redline, definitely worth investigating.
I'm about to pull the top of my intake manifold off to do injectors. I should be right if i just use a genuine nissan gasket and clean is with a razor blade before i put new gasket on yeah?
No need to take the top of the plenum off, I did my injectors and only removed the crossover pipe and throttle body. Used a 13mm ratchet ring spanner for the front fuel rail bolt and socket/ universal/ 6" extension for the rear bolt, you will need 6mm hex for the 4 throttle body cap screws.
Edited by Missileman
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
