WIP:
Ceramic roller bearing SS-4 Turbocharger prototype 1. I've made two types of comp wheels and 3 types of turbine wheels to trail and the profile with the best result will be released. It will be running a .82 Alpha turbine housing.
I'm targeting about 480rwkws mark with the new cams and E85 with 20psi around 4500RPMs. Assume my 850cc injectors don't run out and nothing breaks.
This particular one will cost $2500 to build. how ever I will have it configurated to be the most responsive turbocharger in its HP range.
  • Like 1
He did say that's assuming he doesn't run out of injectors, so it's likely he knows he probably will and is going to see where the but stops before he outlays on new ones.
Stao just so you know I am doing great with my Five-o injectors, a set will run you under $600 for the RB25 and come in sizes up to 1200 for factory fit.
BTW I will probably be adding an external gate to my combo so will have some room to add a VNT housing if you would like me to trial. Drop me a PM.
The current injectors started to run lean on 431rwkw, probably be out towards 450rwkws or might not get there. Will shop for larger injectors.
I will also be targeting response just like other Alpha series turbochargers. Its cool if I ended up with the most responsive 430rwkws.
Result of our recent high flowed R34 OP6 turbocharger. This turbocharger is using our upgraded high flow profile.
Tuned by Toshi on a Mainline roller dyno, made 270rwkws on 18psi of boost with factory actuator pump 98 fuel. By judging the shape of both boost and power curves this turbocharger is capable of running higher boost then what it has been set to. at 22psi is should be getting very close to 300rwkws mark.
Further updates. Just completed the SS3 Alpha prototype-1. There is a dealt about compressor surging using a wheel in this size with fall over blade design, specially working with VNT turbine. So I've made two set of sleeves that goes into the current compressor housing. One is anti surge while the other one is normal. If Trent has time we will be trailing the affect of having an anti surge compressor housing.
That's an interesting way to get the ported shroud in a normally plain housing . I's something that I'd like to see with T04E housings as well because it seems like HKS and Garrett are the only ones with port shrouded E housings to suit Garrett wheels .
A .
Love the bullet nut and overall look of the turbo. Starting to put out some awesome looking turbos
I'm interested in the effects of the anti surge. Its probably at least semi useful on that turbo but I'm not sure why HKS decided my little turbo needed it.
Turbo is installed and I've taken it for a quick test drive, untuned. Well its not responsive as the other alpha series turbochargers, How ever is very responsive for its size. Even it is bigger, but much more driveable compare to the ATR45. I've taken a small footage of the turbocharger on idle then shutting down. While the ATR45 didn't spin much on idle.
Hi Stao,
Just a question about your brae manifold, was your made special in terms of the wastegate position or did you just use the normal one that they make? Also how much for one of your 50mm gates?
Hi Stao,
If you are getting him to make you one you should be able to have it where you like :)
Stao,
You should get a stencil made up and spray on your name "HYPERGEAR" on the compressor cover. Or some other way. Very interested to see the effect of anti-surge.
Josh.
Yeah I know but I just wanted to get it same as Staos run since hes tested it and shown it works well.
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
