Manuel Kasko Posted September 29, 2013 Share Posted September 29, 2013 Stao does that then mean the water lines etc will line up perfectly or will they be the same as my current SS1PU. I had a huge headache with the r33 organising the oil return and the water lines when fitting it so I thought if I stuck with the stock setup for the R34 then I wouldn't have that issue again. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7044213 Share on other sites More sharing options...
hypergear Posted September 29, 2013 Author Share Posted September 29, 2013 The SS1PU has the smaller bearing housing. So they are same the as earlier version. G2/SS2 and larger versions runs the larger T3x bearing housing. Those are easier to install. Best to have a look at the installation walk through for both in page 1. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7044220 Share on other sites More sharing options...
Hanaldo Posted September 29, 2013 Share Posted September 29, 2013 Can reuse factory compressor end, not the turbine end. Which gives it a factory look. Birds. For the drags you will need some 275 MTs, run them at 18psi, and worm them up nicely. If the launch is perfect then a good time is more promising. One thing I didn't like about Heathcote is how they washes rubber residuals at the start of runway with water every time a car lunches. So we always taking off on wet tires. They do that at all drag strips, just go around it... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7044233 Share on other sites More sharing options...
hy_rpm Posted September 29, 2013 Share Posted September 29, 2013 Burnout get that off Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7044402 Share on other sites More sharing options...
methz Posted September 29, 2013 Share Posted September 29, 2013 I wouldn't run 18psi in the mts , more around 12-14psi. and doing a warm up burnout u will flick any water off. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7044439 Share on other sites More sharing options...
Birds Posted September 30, 2013 Share Posted September 30, 2013 I can't fit 275s without some serious bubble; I only have 9 inch wheels and they come out quite wide to the guards already Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7044812 Share on other sites More sharing options...
GTScotT Posted September 30, 2013 Share Posted September 30, 2013 Can anyone with an SS1PU and a Z32 AFM please check their peak AFM voltage on WOT (preferably 3rd of 4th gear) ?? Stao if you can ask Trent for this that would be great also. Thanks, Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7045068 Share on other sites More sharing options...
hypergear Posted September 30, 2013 Author Share Posted September 30, 2013 I'm running the 275 on 9.5 inches wheels in 17 inches. You can get them to fit. By the way, I've found a local company whom's happy to produce the braided oil lines at a much cheaper price. as well as the quantity that we are producing. I'm happy to deduce $100 off all High flow jobs as we as none special priced listed items. Means your high flow job is now $860, and SS1PU/SS2 is $1350 all including oil lines. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7045093 Share on other sites More sharing options...
V28VX37 Posted September 30, 2013 Share Posted September 30, 2013 ... Also we are a little over stocked with our billet SS2.5's parts. Now offering cheap for $850 each complete turbocharger with oil line. ... ... Means your high flow job is now $860, and SS1PU/SS2 is $1350 all including oil lines. C'mon Stao you're killing me, having bought a regular price SS2 just last week Great prices people, get on em! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7045647 Share on other sites More sharing options...
Manuel Kasko Posted September 30, 2013 Share Posted September 30, 2013 How much would it set me back to have my current SS1PU put into a stock R34 turbo stao? Pm me Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7045662 Share on other sites More sharing options...
hypergear Posted September 30, 2013 Author Share Posted September 30, 2013 will cost $150 for the machinery work on the comp housing and back plate. I will need a stock housing supplied to do this. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046014 Share on other sites More sharing options...
Lithium Posted September 30, 2013 Share Posted September 30, 2013 Any progress on the 500kw mission? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046070 Share on other sites More sharing options...
Manuel Kasko Posted September 30, 2013 Share Posted September 30, 2013 That's awesome thanks Stao. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046261 Share on other sites More sharing options...
Lithium Posted October 1, 2013 Share Posted October 1, 2013 Lol awesome, that's hilarious Good luck for the weekend, will be interesting to see! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046738 Share on other sites More sharing options...
scotty nm35 Posted October 1, 2013 Share Posted October 1, 2013 12psi? Cmon mate, wind the wick up. lol. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046741 Share on other sites More sharing options...
GTScotT Posted October 1, 2013 Share Posted October 1, 2013 Can anyone with an SS1PU and a Z32 AFM please check their peak AFM voltage on WOT (preferably 3rd of 4th gear) ?? Stao if you can ask Trent for this that would be great also. Thanks, No members with an SS1PU want to help out a member who does his best to help everyone he can? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046926 Share on other sites More sharing options...
Manuel Kasko Posted October 1, 2013 Share Posted October 1, 2013 I don't have a multimeter sorry mate Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7046973 Share on other sites More sharing options...
Missileman Posted October 1, 2013 Share Posted October 1, 2013 A computer log of any of your dyno runs will have the MAF voltage. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7047033 Share on other sites More sharing options...
GTScotT Posted October 1, 2013 Share Posted October 1, 2013 I don't have a multimeter sorry mate If you have a powerFC it will show on the handjob (hand commander), or it will show if you have the software for a nistune if thats what you run. If anyone has access to either of the above with the same turbo please let me know what reading they are getting at WOT in higher gears peak reading. Birds don't you run a PFC with your SS1PU? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7047076 Share on other sites More sharing options...
hypergear Posted October 2, 2013 Author Share Posted October 2, 2013 Lol awesome, that's hilarious Good luck for the weekend, will be interesting to see! Yes indeed, in fact all the guys at tires joint were beating wither this is car has an intercooler or an oversized radiator. I just made 1 person $100 richer today, no one thought this is a turbocharged kia. Ended up with some 225 / 65 / 16 Nitto tires. Still wheel spinning and torque steer all over the places. MT don't make any tires in this size. How ever this result might give a little indication of what the SS1.5 would do on a SR20det motor, knowing the .64 might be a little chockish, this is running a .86 FNT rear with a 66mm compressor. We were been able to add an additional 5 degrees of timing compare to what it was in the .64 rear. Because the additional timing down low and up top, we ended up picking up 40kws with out getting additional lag. At about 20psi this turbo would be an idle turbocharger for a SR, with similar response to a Disco. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/442/#findComment-7048616 Share on other sites More sharing options...
